Oil getting a little...hot
Discussion in 'Expediter and Hot Shot Trucking Forum' started by ITHotshot, Jul 6, 2019.
  1. ITHotshot
    ITHotshot Bobtail Member
    20
    6
    Jul 4, 2019
    So Im climbing these hills in Wyoming in a Ram 3500 Tradesman hauling a 16000 lb toy hauler. Im keeping it slow at about 55 to keep the rpm's low. Despite this oil temp has risen to 266°F and the coolant to ahout 233 (which holds steady here). Is this normal or do I got something wrong somewhere? Just got the oil changed. I'm using Rotella full synthetic 5W-40
  2. Stubby T Slapnutt
    Stubby T Slapnutt Light Load Member
    168
    131
    Jul 20, 2012
    Maybe drop a gear, stay at 55 mph, you might be lugging it.
  3. Roberts450
    Roberts450 Road Train Member
    1,730
    2,362
    Feb 6, 2016
    Yea get the RPM's up to 2200ish and she will cool right off. You are lugging the engine.
    singlescrewshaker and D.Tibbitt Thank this.
  4. D.Tibbitt
    18,033
    Let her run , get them rpms up and let the engine do the work it was made to do
    singlescrewshaker Thanks this.
  5. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,879
    May 13, 2018
    dam those little diesel oil temps get hot huh. and so does the coolant. wow
    Must be all that emissions junk on the truck which will eventually kill that thing
  6. Concorde
    Concorde Heavy Load Member
    863
    1,570
    Jun 29, 2016
    West Melbourne Florida
  7. Rubber duck kw
    3,654
    8,437
    Dec 9, 2017
    What are you at for rpm, probably need to get it wound up a little higher.
  8. ITHotshot
    20
    6
    Jul 4, 2019
    At 55, around 1500.
  9. olddog_newtricks
    olddog_newtricks Medium Load Member
    359
    902
    Jun 3, 2018
    Drive it like you stole it it'll be ok.
  10. Rubber duck kw
    3,654
    8,437
    Dec 9, 2017
    Yea that's a little low, I have an 05 5.9 and pulling anything I try to keep it around 1700, it gets pretty hot below that.
  • Draft saved Draft deleted
