I have oil leaking from the left bottom monunting nut of my turbo it actully appears to be leaking from under the nut while the engine is running and not the gasket plus i just replaced gasket less a month ago nut is tight anybody got any ideas whats going on here?
Oil leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by sodbuster94, Nov 25, 2018.
My bet is either the oil supply or return gasket needs replaced.
I would replace both.
At the exhaust manifold attach point the bottom left bolt has oil bubbling out around it
JohnC123 Thanks this.
Pics i took last night
