Oil pressure very low Cummins isx
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Nov 18, 2020.
  1. Gurjap
    Gurjap Light Load Member
    55
    11
    Mar 18, 2020
    Hey friends I have a 2010 kenworth t800 Cummins isx engine and my oil pressure becomes very very low and the truck stalls. Then when I turn it off for 5-10 minutes I everything goes back to normal but not for long. When I change the filter it goes 2-3 weeks no problem and then after that the pressure starts to get low again. Any help will be greatly appreciated.
  3. abyliks
    abyliks Road Train Member
    3,085
    6,903
    May 2, 2010
    ludlow MA
    How low is it going? Not sure about the isx but Cummins used to be low pressure/high volume
  4. snowwy
    snowwy Road Train Member
    19,789
    12,333
    Jul 6, 2009
    When was the last oil change?
    bzinger Thanks this.
  5. mitmaks
    mitmaks Road Train Member
    2,450
    1,952
    May 16, 2014
    How low does it get? Cummins is usually 20 psi at idle and 40 when at 1500+ rpm
  6. lester
    2,819
    7,479
    Jan 2, 2012
    NW, Iowa
    Are you using antifreeze? Get an oil sample and see whats plugging your filter
  7. AKDoug
    AKDoug Medium Load Member
    323
    800
    Mar 21, 2018
    Had a very similar issue when my EGR cooler started leaking into the intake stream on one of my trucks. Never had it stall the truck though.
  8. snowwy
    19,789
    12,333
    Jul 6, 2009
    The one time I had that problem. All 6 piston rings were broken. Shop was changing the oil every 2 weeks till they got around to replacing the pistons and cylinders.
    baha Thanks this.
  9. MTN Boomer
    MTN Boomer Road Train Member
    1,157
    1,960
    Feb 4, 2019
    The last Mack I drove went through 2 gallons a day, still ran strong , got up to 3 or 4 a day, finally locked up.
