Ok if im close to over 80,000 ....
Discussion in 'Questions From New Drivers' started by Midnight Mike, Sep 9, 2012.
  1. Midnight Mike
    Midnight Mike Light Load Member
    83
    40
    May 18, 2012
    Drumright,Ok
    And i need to weigh myself i have a app that can locate cat scales but im concerned in passing an official weigh station before getting to the cat scale..how do you pros do it?
  3. Cranky Yankee
    Cranky Yankee Cranky old ######
    15,317
    209
    Jan 31, 2012
    Green Bay Wi
    i ask shipper where closest scales are watch on way in to every shipper locate scales and weigh stations
    dont even have to be close on 80000 just over on an axle
    every hole on trans am trailers is 300 lbs you move towards the problem
    DrtyDiesel, A21CAV and Midnight Mike Thank this.
  4. DrtyDiesel
    DrtyDiesel Road Train Member
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    I'm not a pro but I use an app called truck and travel. It does cost a few dollars but I use it every day. It shows where scales are, also truckstops, rest areas, walmarts, and low clearance locations. Also shows what amenities the truck stops and rest areas have. Gives the option of opening Google maps for a route to the location, has the phone number stored. I've used it many times to get around scales to get to a cat scale.
    Ethan
  5. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    Also, app is available on the android market, not sure if its available on iPhone or not.
    Ethan
    Pirate Trucker XOXX Thanks this.
  6. Countyboy
    Countyboy Medium Load Member
    495
    179
    Nov 10, 2010
    Littleton, NH
    Well, head to the scale. Before you go look at where the end of the load is inside your trailer and set the center of your tandems at the end of where the load stops in your trailer. Tried to do a picture with text but forum won't allow it. Hope you get what I mean
    A21CAV Thanks this.
  7. Midnight Mike
    83
    40
    May 18, 2012
    Drumright,Ok
    Checked out the app saw a lot of good ratings,downloaded it and its perfect, thanks :)
    DrtyDiesel Thanks this.
  8. Countyboy
    495
    179
    Nov 10, 2010
    Littleton, NH
    Another good app to get is Truck Stop by Leigh Gagnon. Will list truck stops by distance from you or on by state/interstate. Gives you info such as parking space numbers, showers, TRIPPAK/transflo, # of fuel islands, restaraunts, nearby shops etc. also can find scales, Walmart, repair shops, tire shops, look at notes on wether truxk stop is dirty or not etc. it's VERY useful and cheaper then the truck stop book
  9. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Hopefully you have a tractor bag pressure gauge and know how to "guesstimate" drive weight and can extrapolate from there. Otherwise do what you have to do. A good (current) carrier atlas will show where the scales are with an arrow.
  10. DrtyDiesel
    5,348
    2,598
    Feb 14, 2010
    Jacksonville, FL
    No problem. I like it because it shows the map just like Google maps but with little pins that pop up showing what's there. I use it to find out what truck stop I'm going to stay at when I shut down for the night along my route. I open it up in Google maps and it gives me the ETA. That's how I usually trip plan for the day.
    Ethan
  11. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    I have on-board scales, drives and trailer, don't need to go anywhere but a fairly level spot in the shipper's parking lot.
