One serious p.o.s. cooler
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by ratchetjaw, Apr 29, 2008.
  1. ratchetjaw
    ratchetjaw Light Load Member
    209
    19
    Mar 30, 2008
    Iowa
    Got a 40 Quart PowerChill™ Thermoelectric Cooler with Power Supply by a Well-known Outdoor Equipment Company.
    Am taking the thing back and getting something else.
    The 7.5 fuse in the 12 v plug melted into the plastic. I will get it out but am returning the thing anyway. Burned hand trying to unplug it and it can't be "on" for more than 5 minutes without heating up dangerously.
    Have sent a message to the Well-known Outdoor Equipment Company letting them know what I think of their cooler.
  3. panhandlepat
    panhandlepat Road Train Member
    3,255
    2,243
    Jan 12, 2007
  4. ratchetjaw
    209
    19
    Mar 30, 2008
    Iowa
    Sure 'nuff. I have heard good comments about them but this one is, well.... opinion already clear, eh? :biggrin_25525:
    I am still trying to get the fuse out... willing to give the unit another try while I have it here.
  5. pjw044
    pjw044 Heavy Load Member
    Had 2 do the same thing in 3 months-both came from wally-world from two cities 1000 miles apart...both took them back without problems..
  6. panhandlepat
    3,255
    2,243
    Jan 12, 2007
    the one i bought a few weeks ago says "new" on the top left corner of the box. it doesn't have a fuse in the plug and is not even getting warm much less hot enough to melt like my previous one did.
  7. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    This is common with the Coleman coolers. I had 1 that did the same thing. Apparently when they attach the plastic housing over the fan at the factory they do not take the time to restrain the wiring underneath or protect it in any way. The metal screws knick the wiring underneath and the end result is the cord gets hot enough to melt.
    I replaced the cord with a new cord from the factory and discovered the knicked wiring underneath. I wrapped the wiring with some electrical tape and carefully replaced the plastic housing. The cooler works fine now.
  8. ratchetjaw
    209
    19
    Mar 30, 2008
    Iowa
    Taking this one back and will check it before I leave the parking lot.
    Thanks for the info on the wiring. Even if the next one doesn't overheat I can take the housing off and redo whatever needs to be done.
    Don't you just hate paying good money and have things turn out bad?
  9. jlkklj777
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    You may have to contact Coleman directly. In my case I did call them directly and they replaced the cord gratis. Shortly thereafter I had to call them again and complain about a grinding sound in the motor. I put the phone by the motor and explained the cooler stopped cooling as well. They immediately sent me a brand new cooler from the factory.
    I suspect I got a "returned" unit to begin with and thats why I had so many problems. I did take the time to remove the fan cover and wrapped the wires with electrical tape and then put it back together just to be safe. I sure do not need to burn the truck up with me in it!
    Good luck!
  10. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    My biggest complaint with all of those coolers is that they do not cool enough. Especially in the summer. Winter is tolerable but summer your sandwich meat, cheese, milk, orange juice etc just plain doesn't stay cold.
  11. jlkklj777
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    Your right. I believe they only "cool" the inside of the cooler 30 to 40 degrees colder than the exterior. If you routinely shut off your truck to save fuel then the inside of the cab may get up to 100+ degrees. You can get seriously sick if you don't watch it with the dairy stuff.
