If the truck No have Overdrive it's big deal or dosnt matter what time you need it and what time you No need it ....
If the truck non overdrive will feel it weak
And can make different on fuel mpg ?
The truck. .Cascadia DD15 Detroit
Ratio ..3.42
Transmission DT12 auto
Overdrive /No
HP / 455
trailer -53 reefer
Load around 35k.lb
Overdrive in trucks important or never mind
Discussion in 'Ask An Owner Operator' started by Mahertruck, May 30, 2017.
It depends on how it is spec'ed and what it is used for. I've driven many direct top gear trucks that just plain sucked and many trucks with od that equally sucked.
1951 ford Thanks this. -
My best guess is that DT12 transmission is the overdrive model, if was the direct drive model the rear axle ratio would start with a 2, for example a 2.47.
Studebaker Hawk and ChicagoJohn Thank this. -
Dt12 is probably same as Volvo 12 speed... 11th is likely direct and 12 is over drive and the ecm only uses 12 when conditions are favorable to do so. Simply asking if overdrive is necessary is a wide open question. Over drive just means the output shaft spins faster than input shaft of transmission. You have to match it up with a rear end gear and then you get your final reduction.
Take a look through cowpie1's posts - he has 2.64 rear end with double over transmission and he does just fine. The flip side for him he will have to use the really small gears to start moving with a heavy load but in the top gears he has tons of speed available, more than you'd ever legally need. The other side is a direct drive transmission with say 4.10 gears - this truck would pull a huge load over a mountain, but would top out at a relatively low speed. You will find heavy haul trucks similar to this. What you want is something in the middle. -
The truck Specifications ...
Ratio .. 3.42
Transmission DT12 auto Detroit engine
Overdrive /No
HP /455 ...
The loads like I said reefer 53
So you think with this kind of loads without overdrive option or better I find other one has overdrive option available it's depends on the loads or depends on highways you runningLast edited: May 30, 2017
Oxbow Thanks this. -
There is a magic gear combination that will get you 10 mpg
If you send me $300 I'll tell you..Oxbow and PhilKenSebben Thank this. -
Overdrive or no overdrive depends on the rears. I think 3.42 is a little low for no overdrive. It won't feel weak. The opposite. Fuel mileage will suffer with 3.42's and trying to run 70 mph. That's a 58mph truck with no overdrive. I think it's a typo though.
It sounds like he is assuming the listing in Truckpaper or whatever is in fact correct. Just some lazy salesman who doesn't want to look up the exact specs on that truck so he clicks on the listing "no overdrive"
noluck Thanks this.
