Someone told me it's illegal to have pressurized gas bottles in a truck. Apparently, it's the big tanks, but I think a rookie cop would question it. And with all the stuff everybody wants to carry, you may as well pull doubles and have one as an equipment trailer,,
Parts to carry
Discussion in 'Ask An Owner Operator' started by LDLWells, Dec 13, 2019.
Page 4 of 6
Dunno if I missed it but a few of these. Have had them rip or blow out enough to the point the trailer brakes wouldn't able to hold enough air and drag. Less than a buck and can save a road call.
Rideandrepair, Dino soar, D.Tibbitt and 1 other person Thank this. -
Rideandrepair and FlaSwampRat Thank this.
Rideandrepair, D.Tibbitt and 062 Thank this.
line. Tricky... burn the line or drip phosphorus on your hand.Rideandrepair and FlaSwampRat Thank this. -
I didn't forget about this. Just waiting to get on a PC to clean and format it for easier reading
Rideandrepair Thanks this. -
I do not recommend battery impact wrenches as I personally rarely use them. They’re mostly for removing bolts quickly, but they can also break bolts. Doing it by hand decreases the chances of breaking bolts. The exception is if you want to remove your lug nuts in which case you can get a Milwaukee that can do at least 1400 ft lbs.Last edited: Dec 19, 2019
One other thing I do is keep bolts,washers and such in old vitamin bottles and the like. I also pick up any bolt or washer I see. I picked up a pipe plug once that saved me no telling how much on a service call.
If recommend have couple of large rolls of exhaust tape. I have hole in exhaust flex pipe and its leaking exhaust to point of derating. If I had some exhaust tape is be able to patch it up and go
I skimmed through and don't recall seeing a air line set up with a gladhand. I keep one in the truck to air up low tires and it has saved me more than once. Just hook it to the red line and release the trailer parking brake and you have a way to pump up tires or run an air tool.
If used for an air tool past experience has been that the output will not be as high as would be on a normal compressor. My guess is because of the small supply line.
Possible solution would be a fitting in the air tank with a quick release to accept the air line. Maybe someone else with some more experience would have a better solution.D.Tibbitt, Rideandrepair and PE_T Thank this.
Page 4 of 6
