people net volume control?
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by randomname, Sep 19, 2014.
  1. randomname
    randomname Light Load Member
    Jul 13, 2014
    244
    Thanks Received:
    262
    If I get another " stay alert and safe and rested" message waking me up I may push this truck off a cliff. I have pushed all of these seemingly cosmetic buttons on my peoplenet unit but can't get it to shut up. What am I missing?
    Thanks
  2. dragnfly253
    dragnfly253 Bobtail Member
    Jul 12, 2014
    Thanks Received:
    Look under system then settings. You should see a slider that lets you lower the volume.
    randomname and Ebola Guy Thank this.
  3. Cody1984
    Cody1984 Medium Load Member
    Jan 24, 2014
    419
    Thanks Received:
    249
    PA
    Volume adjustment along with brightness is under settings.
    Ebola Guy and randomname Thank this.
  4. Ebola Guy
    Ebola Guy Heavy Load Member
    Oct 11, 2009
    977
    Thanks Received:
    789
    Manitowoc, WI
    Oh, thank you, Dragonfly and Cody! I just moved into a PeopleNet truck and that is one of the things I wanted to know. I just also found out I could customize the home screen. Kudos to you, sirs!
    Now I just have to figure out how to delete those 'suspended' or 'pending' messages.
  5. lovesthedrive
    lovesthedrive R.I.P.
    Nov 11, 2008
    15,953
    Thanks Received:
    54,484
    Sorrento Maine
    If you have a cooler, you could put it inside the cooler and close the lid to keep whom ever from bypassing the settings?
    Case in point. Wife and I got a digital AT&T answering machine. We set the volume to zero, in the winter Walmart will spam our home phone. Some how when they call, the volume is getting remotely altered and becomes a seven! Next thing we know we have a voice blaring away about something we have no interest about.
  6. dragnfly253
    Jul 12, 2014
    Thanks Received:
    To get rid of suspended messages go to System =} Information =} Services. Highlight empty mailbox and hit OK. If you mt the drafts folder it will delete all pending and suspended messages. While you are here you can also clear out all the other messages you don't want. You will have to clear each folder individually. When you answer yes it takes a few minutes if the folder is very full. Hope this helps.
    Ebola Guy Thanks this.
  7. 123456
    123456 Road Train Member
    Oct 22, 2010
    10,555
    Thanks Received:
    5,746
    32179
    I do not suggest, but,
    on some units,
    a few drops of superglue muted the volume....
  8. randomname
    Jul 13, 2014
    244
    Thanks Received:
    262
    Thanks guys!
