Performance Air Filters for a W9 with Cat motor.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ProfessionalNoticer, Aug 22, 2021.
  1. ProfessionalNoticer
    1,441
    2,999
    Apr 25, 2021
    Is there such a thing? Of not; who makes the one that has the most flow for a tuned Cat in W9?
    blairandgretchen Thanks this.
  3. 062
    062 Road Train Member
    4,923
    10,407
    Oct 20, 2013
  4. benjamin260_6
    benjamin260_6 Medium Load Member
    412
    445
    Aug 8, 2012
    Ontario, Canada
    Fleet air filters. They're a foam/oil filter. As long as they're oiled properly (you'd be surprised how many people think they're doing it right but aren't) they flow better than a new paper filter and filter considerably better
  5. ProfessionalNoticer
    1,441
    2,999
    Apr 25, 2021
    I just got my oil analysis back from Cat after my rebuild and the silicon was elevated at 21. Not sure how bad that is.
    BigBob410 and blairandgretchen Thank this.
  6. blairandgretchen
    9,788
    44,149
    Dec 9, 2011
    South west Missouri
    It’s not bad. Typically they won’t flag it till 50 ppm.
    Still - less is better.
    I run an Amsoil BP filter, and I’ve got the Fleet Air.
    Much more sucky sucky vroom vroom.
    Very technical information I know.
    BigBob410, ProfessionalNoticer and 062 Thank this.
  7. ProfessionalNoticer
    1,441
    2,999
    Apr 25, 2021
    I just realized those paper filters had 30k on them. I used to change them out every other PM and those were done at 10k intervals. So I was halfway to bad silicon territory with the 21. No bueno.
    So which of the sucky sucky vroom vroom do you think is the better of the two you're currently using?
  8. blairandgretchen
    9,788
    44,149
    Dec 9, 2011
    South west Missouri
    I fully recommend a bypass filter - the Amsoil was about $350 - vs that overpriced KR thing.
    Good thing about foam filters - clean every 10-15k, or when you’re bored. Every time you do, you’re saving the paper filter cost.
    To me - it’s about the most important thing on a combustion engine - clean and maximum airflow.
    ProfessionalNoticer and BigBob410 Thank this.
  9. BigBob410
    BigBob410 Road Train Member
    5,386
    71,548
    Feb 2, 2016
    Beirut on the Bay, MD.
    I thought it was sucky sucky boom boom vroom vroom.... I’m guessing these reusable foam filters are the big truck version of a K&N?
  10. blairandgretchen
    9,788
    44,149
    Dec 9, 2011
    South west Missouri
    I’ve only heard of K and N.
    The FA filters are a 3 wrap Velcro fastened foam sheet around a metal cage.
    I noticed you can actually hear the turbo better after installing.
    Who doesn’t love the sound of a turbo spooling up?
  11. rollin coal
    rollin coal Road Train Member
    11,070
    17,781
    Mar 29, 2008
    TN
    Silicone is basically dirt. It's normal for that to be a little elevated after a rebuild or sometimes even an overhead. In my opinion though it shouldn't spike after an overhead, but it might. Who does your oil samples? If it's CAT call them up and ask about that, they'll answer your question. I started using Blackstone Labs with my Detroit. And they will definitely explain a sample mostly without the need to call them and ask for more info. They cost a little more but I think are worth the extra $. As far as air filters I've always preferred Donaldson. Not really a fan of the oiled filters but to each his own.
  • Draft saved Draft deleted
