Pete power window Problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jim205, Mar 6, 2021.
  1. jim205
    jim205 Bobtail Member
    i have a problem with a 2010 Pete when you attempt to use the window switch window does not work but it does light up all the dash illumination lights replaced the switch and the regulator which was bad but still have the same problem but if i bypass the switch the window works as it should? any suggestions ?
    Trucking Jobs in 30 seconds
Draft saved Draft deleted
