Hello my name is Trav Ratta , I am a self tough michanic and am in charge of michanical repairs for a construction company ,,, my brother also welds for the same company we are wanting to build a peterbuilt 351 with butterfly hood and run about 1000 hp , I would like to put a cat c18 in it doesn't any one Know if it will fit in the frame or have suggestions on another engine and what the best way 2 hit that hp number and also what trans should I go with ,, I'm my ideal world I would go with 18spd, any advice would be appreciated thank
Peterbuilt 351 with butterfly hood build
Discussion in 'Peterbilt Forum' started by Trav, Mar 12, 2018.
How about some pictures one post Trav?
Before I built a 1000 hp pete I would learn to spell Peterbilt.
ajax1337, project359, blacklabel and 8 others Thank this. -
I will be kind of curious to see what you come up with in regards to a radiator that will keep the engine cool.
You might need to come up with a custom job a foot thick to keep that engine cool.Blackshack46, Roger McG and AModelCat Thank this. -
To OP, the C18 has the same external dimensions as a C15, which is smaller than an 855 Cummins. 855 Cummins were installed new in 351s, so a C18 should fit.BigBob410, Oxbow, sdaniel and 1 other person Thank this. -
BoxCarKidd Thanks this.
rabbiporkchop Thanks this.
What I was getting at earlier with my air to air comment was there simply might just not be enough room for a bigger rad and air to air to accomodate that kind of power.
