Pilot installing tire pressure sensors at fuel pumps. Sends info to your company
Discussion in 'Other News' started by JC1971, Jul 29, 2022.
  1. flood
    flood Road Train Member
    4,029
    3,770
    Dec 25, 2010
    a air pressure sensor is mounted inside the tire (battery powered) with a low power radio transmitter...
    The truckstop has a receiver at the pump it pick up the reading..
    A cars system works the same way...
  3. GYPSY65
    GYPSY65 Road Train Member
    1,938
    5,218
    Nov 16, 2012
    SW FLA
    There’s a scale In the NE that has this on the hwy
    I had just put new trailer tires on and the shop a) had a loose stem and b) forgot to turn the auto air system I have back on
    Scale pulled me in and said left rear outside tire is low
    They let me tighten and air up the tire with no issue but this does already exist
  4. flood
    4,029
    3,770
    Dec 25, 2010
    the weight stations system uses a inferred camera system to see heat differences between the tires (low tires run hotter) the same system checks heat differences in brakes to see ones out of adjustment
  5. D.Tibbitt
    130,560
    Thats fine they can send it to my safety guy. he is a lazy idiot anyways and needs some extra work!
  6. sirhwy
    sirhwy Medium Load Member
    347
    709
    Sep 1, 2011
    Central Iowa
    We have the cat eyes on the drives that show if set of tires is low. We have auto inflation system on the trailers. Wonderful system. I walk around and check all of them them every time I stop. I also check reefer temp and generally check the trucks over all condition as well as getting in a few extra steps. My dispatcher has plenty to do as it is without having to worry about tire inflation. That’s my job.
  7. sevenmph
    sevenmph Road Train Member
    2,932
    14,086
    Jan 26, 2007
    Pinellas county Florida
    It's mounted on the back of the valve stem in most cars. If you change a wheel or stem it has to be synched with the car. There is also the type that is integrated with the ABS sensor on cars and judges wheel speed since all 4 should be turning at the same speed. It's not as accurate.
  8. Tumbleweed TowMan
    Tumbleweed TowMan Medium Load Member
    390
    1,713
    Jun 22, 2022
    Blasted computer hoohah, next they'll be ratting to the corporation if yer wearin' skid marks.
  9. O.Henry
    O.Henry Road Train Member
    1,039
    1,825
    Sep 1, 2012
    San Antonio,TX.
    Got stopped on a scale.
    Weighmaster told me to set my breaks,he need to check something.Walked around and thumped my passenger side drives,walked back around and told me to go. Don’t know how long they’re going to do that.
  10. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,261
    Nov 14, 2021
    ALBERTA
    Third party supplier selling TPMS systems.
    Sensors can be installed on each tire and can be read remotely.
    Not cheap, though.
    18 Sensor Eighteen Wheeler Tire Pressure TPMS w/ Display – Computech
  11. Another Canadian driver
    1,181
    4,261
    Nov 14, 2021
    ALBERTA
    One or more tires reading too hot by his camera.
    Underinflation tends to do that to a tire.
    He found no issues, he let you go.
    O.Henry Thanks this.
