Power steering lines over heating
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by newfdrvr, Mar 16, 2017.
  1. newfdrvr
    newfdrvr Bobtail Member
    7
    houston, tx
    I have a 2013 Freightliner cascadia
    All three power steering lines are hot almost immediately after starting the truck. I replaced the power steering pump. All three lines still get hot. Any ideas what the problem might be???
  3. pigeon river trucking
    pigeon river trucking Light Load Member
    132
    99
    Jan 1, 2016
    michigan
    Does it have a filter in the Reservoir.
  4. newfdrvr
    7
    houston, tx
    Yes. But it broke off and was laying in the reservoir. I assume this is probably the problem then??
  5. fargonaz
    fargonaz Road Train Member
    1,167
    4,582
    Feb 9, 2015
    Mesa, AZ
    Is there a problem other than you think the lines are hot?
  6. pigeon river trucking
    132
    99
    Jan 1, 2016
    michigan
    Not if it is broke off a plugged filter will overheat fluid. How hot r they getting normal would be 180 200
  7. pigeon river trucking
    132
    99
    Jan 1, 2016
    michigan
    They r hooked to a engine that gets to hot to touch
  8. SLCTrucker
    SLCTrucker Medium Load Member
    404
    199
    Jan 15, 2009
    Salt Lake City UT
    Change out that filter & I would suggest switching to full synthetic fluid.
    newfdrvr Thanks this.
  9. newfdrvr
    7
    houston, tx
  10. newfdrvr
    7
    houston, tx
    OK I will replace the filter and the cap. Since the threads broke off of the cap that the filter threads to. Hopefully this will fix the problem.
  11. jamespmack
    206,885
    Check starter and battery grounds. This was a issue in 2001 century's. When grounds are bad. The next ground is normally the power steer hose with steel braid inside. 2000/2001 the didn't weld the ground stud in frame all the way around. Then corrosion would build up. Then power steer lines would melt.
    NCTru919, fargonaz and Ooops Thank this.
