Power supply /phone charge port
Discussion in 'Ask An Owner Operator' started by feldsforever, Aug 2, 2021.
  1. feldsforever
    feldsforever Road Train Member
    1,061
    1,018
    Nov 22, 2019
    It does not work and is not fuse related, any ideas? 1627897650609853051646.jpg
  3. Oscar the KW
    Oscar the KW No Filter
    11,716
    24,846
    May 19, 2011
  4. InTooDeep
    2,372
    11,585
    Jan 17, 2016
    Carmichael CA
    Wire or socket itself i have had to change out a couple of those
    feldsforever Thanks this.
  5. ProfessionalNoticer
    ProfessionalNoticer Medium Load Member
    467
    674
    Apr 25, 2021
    Check the wires at the socket with a test light. If there's power, the socket is bad. I bet you have a broken wire somewhere though if your fuse is good. Try another new fuse too. Sometimes they can be blown and not visible.
    Team818 and feldsforever Thank this.
  6. 86scotty
    86scotty Road Train Member
    2,942
    6,959
    Aug 27, 2017
    Appalachia
    Nope, it's not the wire. The ones that point to the sky like that just absorb dust, dirt, coffee, etc. Even if they are capped they still get cruddy.
    1. Take fuse out
    2. Use wire brush and compressed air to clean up the inside, especially the center contact.
    3. Replace fuse
    If this doesn't work pop it out and put a new one in, $5 on Ebay/Amazon/wherever.
    feldsforever and InTooDeep Thank this.
  • Draft saved Draft deleted
