I work for first fleet and they just recently started having the drivers do a pretrip and postrip for each trailer they pick up during the day. So if I have three trailers I will have 3 pretrips and 3 postrips . I was always under the assumption that you had to have a pretrip at the beginning of the day and a postrip at the end of the day. I understand that you have to do a dvir for each piece of equipment, but it doesn't make sense to do a pretrip and postrip for each trailer. I would think they are opening themselves up to a lawsuit if, heaven forbid one of the drivers hits and kills someone and they did the required beginning of the day pretrip and they did the drop and hook macro, but forgot the to do a postrip and pretrip after a drop and hook. Maybe I am jus missing something..
pretrip and postrip for each trailer during a single day.
Discussion in 'Trucking Industry Regulations' started by Boomer08, Jul 7, 2013.
Page 1 of 3
I'm seeing double vision here,lol.Can you delete one of your threads,they're the same.
bigdogpile Thanks this. -
By the way. I always do a quick safety check of a trailer I've just dropped. If I'm done for the day I include it in my Post Trip. If I'm going to hook to another trailer, I just do my thing, checking for flats is about it. This only takes a minute so I don't log another "safety check". I figure the time is already allocated under "drop and hook" on duty time. -
My company just started making us do a dvir for each trailer we drop. That is to cut down on people dropping trailer that have problems. They will be able to see who dropped it last.
Not sure what that would have to do with any lawsuits. -
roshea and spyder7723 Thank this.
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=396.13
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=396.11
You're gettin crusty in your old age GH! -
You hook that trailer to the truck and it becomes a motor vehicle. You need to do a pre-trip. It's only common sense and you'll be asked in court.
roshea, spyder7723 and 123456 Thank this. -
§ 390.5 Definitions.
Motor vehicle means any vehicle, machine, tractor, trailer, or semitrailer propelled or drawn by mechanical power and used upon the highways in the transportation of passengers or property, or any combination thereof determined by the Federal Motor Carrier Safety Administration, but does not include any vehicle, locomotive, or car operated exclusively on a rail or rails, or a trolley bus operated by electric power derived from a fixed overhead wire, furnishing local passenger transportation similar to street-railway service. -
Thanks for the reference but I would hope everyone that drives a truck would already know this. Sometimes you have drivers that just want to skirt the law to save a couple of minutes so it's good they see it in black and white. Then again you might have some that would argue this too. They'll spend countless hours trying to prove themselves right when we're only talking about a pre-trip. Thanks again.
You do realize that a pre-trip includes the truck right? That means the air leak test, AC/heater, checking the engine compartment, fluids, etc. Every time you hook to a trailer? Really? You are right in that the trailer is considered part of the pre-trip and is also considered a vehicle. But there is no way they expect you to do a full pre-trip if you drop and hook somewhere after your day has already begun. Do an inspection on the trailer, absolutely, but a full pre-trip is silly.
Page 1 of 3
