Primary fuel filter
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by spindrift, May 20, 2022.
  1. spindrift
    spindrift Road Train Member
    3,115
    12,133
    Dec 2, 2014
    Texas
    So I found this "stuff" packed around the inlet ports of my fuel filter. I've never, ever seen anything like it before. Only difference is that my last filter change was done by a TA newbie. It almost has the consistency of caulk. The heated fuel definitely has had an affect on it. Any ideas?
  3. kranky1
    kranky1 Road Train Member
    1,543
    5,500
    Sep 16, 2015
    Ontario, Canada
    Caulk eh. Pipe dope maybe? Have you looked up into the filter head to see if there’s any around the threads? Doesn’t really matter what it is it shouldn’t be there. Almost had to have come from somewhere between there and the water separator. Can’t see any of that going through one, it almost had to come from somewhere downstream of the separator.
  4. spindrift
    3,115
    12,133
    Dec 2, 2014
    Texas
    Interesting. Maybe the kid removed the threaded insert that screws into the center of the filter head and put something on the threads.
    The first and only time I've had someone do the filter change.
  5. Another Canadian driver
    Another Canadian driver Heavy Load Member
    816
    3,114
    Nov 14, 2021
    ALBERTA
    The first and last time I've had someone do the filter change.
    Fixed it for you.
    You are welcomed.
    spindrift Thanks this.
  6. Rideandrepair
    14,130
    46,957
    Aug 8, 2015
    Insides of fuel lines coming apart? Usually looks all black, more consistent. That looks like rat poop.
  7. spindrift
    3,115
    12,133
    Dec 2, 2014
    Texas
    All new fuel lines. Actually, looks like a lot of ear wax plugs that came from a kid I knew in school. :eek:
  8. AModelCat
    121,902
  9. spindrift
    3,115
    12,133
    Dec 2, 2014
    Texas
    LOL, I don't snack while I'm fillin'.
  10. North Pole Nightmare
    North Pole Nightmare Light Load Member
    154
    245
    Dec 15, 2021
    Some fuel has a little tar or asphalt in it.When the fuel is heated it separates and ends up like this.
  11. mtoo
    mtoo Road Train Member
    1,829
    3,941
    Jan 15, 2011
    Retired on bended knee
    I would cut the filter open and see how much was in the pleats. Also check the walls and bottom of fuel tank. I'm going to go with asphaltene if it was algae it would be slimy. All it takes is one fill up from a contaminated storage tank with no filters at the pump to give you months of headaches
  • Draft saved Draft deleted
