Prime issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FREDthaCEO, Sep 28, 2022.
  1. FREDthaCEO
    FREDthaCEO Bobtail Member
    10
    Mar 6, 2021
    Okay I have a 07 Columbia with a c15 in it truck rides fine but my issue is I loose prime sometimes over night or sometimes in a couple of days, and I keep having to fill up the fuel water separator to get it primed but once it’s primed it runs like normal, I’ve change the filters, that ball check valve that’s in the separator housing and the check valve that’s next to the spin-off fuel filter but I still keep losing prime, could this be my fuel pump ?
  3. FREDthaCEO
    10
    Mar 6, 2021
    and sometimes when I am riding in the hwy I feel it jerking or skipping some
  4. ibcalm19
    ibcalm19 Road Train Member
    1,289
    2,033
    Nov 30, 2015
    Pennsylvania
    It is sucking air somewhere in the fuel system. You have to pressure test the system so you can pin point where the leak is.
    FREDthaCEO Thanks this.
  5. MRMTRANS
    MRMTRANS Light Load Member
    120
    128
    Apr 28, 2015
    I have a diesel fuel transfer pump from Harbor Freight. Cost me under $60 when I purchased 10 years ago. Probably double the price now. I have adaptor fittings from Ace Hardware for all the lines in the fuel system to pressure test. A shop is going to to charge you more for 1hr than the cost of buying these and checking yourself. And they probably will charge you for more time to pressure test. I got charged for 2 hrs back in 2011, which prompted me to purchase this setup.
    ibcalm19 Thanks this.
  6. ibcalm19
    1,289
    2,033
    Nov 30, 2015
    Pennsylvania
    I too have that same pump and bought it about 12 years ago
  7. little cat 500
    1,795
    871
    Jan 17, 2010
    Abbottstown PA
    check valve is bad in filter housing
  • Draft saved Draft deleted
