Hey all!
I just purchased a trailer with a hydrolic filp axle and I am concerned with connectors not connected during the winter months. ( when not using the flip ).
Am I worried about nothing? Should I just keep a good coat of WD on them? Do I need to cover them with something?
Or, just wipe them down once in a while and spray WD-40.
I think maybe I'm making a bigger deal than neccessary, but I'd rather not learn the hard way when I need it in a crunch. Thanks ahead!
Protecting Hydrolic and Air Connectors during winter
Discussion in 'Heavy Haul Trucking Forum' started by Hegemeister, Mar 9, 2019.
You can buy another set of couplers and just plug the ends. Will keep them nice and clean and easy to store
SAR, cke and Hegemeister Thank this. -
Yes, but any connector with any air pressure will open. Any hydraulic line will bleed fluid.
cke Thanks this. -
Spray them with something that’s a light oil, get a set of them yellow rubber kitchen gloves cut the fingers off n put them over the fittings tight like a condom.
I would not use wd40 for that. Maybe soak in blaster tho.snowman_w900, rolls canardly, SAR and 3 others Thank this. -
snowman_w900, SAR, cke and 2 others Thank this.
I would put some grease on the hydraulic couplers and not worry.
Get a tennis ball, cut a X in, wiggle over female coupler, done
Been doing this for years, works keeping dirt out , an like me, cheap and easyold iron, Oxbow, Ruthless and 1 other person Thank this. -
Does it work for the electrical connector as well as the air line?
Hegemeister and Oxbow Thank this.
