Pulling doubles first time
Discussion in 'Questions From New Drivers' started by route man, Apr 24, 2014.
  1. route man
    route man Light Load Member
    93
    14
    Jan 13, 2013
    nc
    I been driving for about 9 years and starting next week i will be pulling double,anything special i need to know??
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    if you have a duel drive axle truck, remove your mudflap hangers. (or bungie them pulling forward) In many cases the landing gear is to close to the kingpin and thus will take out your flaps. Also slide 5th all the way back. Other then that its the same...aside from the fact you can't back up...need to make wider turns...and you have 2 5th wheels and a pital hook to check.
  4. lv gn
    lv gn Heavy Load Member
    985
    469
    Jun 23, 2008
    las vegas nv.
    Wiggle wagons? Rocky Mountain doubles?
  5. casc1
    casc1 Light Load Member
    297
    201
    Nov 22, 2011
    toronto
    Just don't watch your mirrors......
    blairandgretchen Thanks this.
  6. route man
    93
    14
    Jan 13, 2013
    nc
  7. blairandgretchen
    13,376
    71,892
    Dec 9, 2011
    South west Missouri
    You'll be fine.
    Don't park in fuel islands behind knuckle draggers, you won't be able to back up to get out after fuelling - while they're still in the restaurant.
  8. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    1. Make sure the heavy pup is up front.
    2. You don't have to swing as wide with them as you do a 53'.
    3. Keep in mind , they are very hard to back. If you get into a situation where you have to back, you will probably have to disconnect and move each separately.
    4. When hooking up, put your inverter dolly in front of the rear trailer, hook the front trailer to the dolly and back the dolly up under the back trailer.
    5. Don't forget to open your air ####pits on the front pup and close them on the back(Where the airlines hook)
    6. Close the air ####pits on the front pup when you get ready to unhook after you've dropped the back pup.
    7. As already stated, Watch the clearance between your tractor mudflaps and the front pup landing gear.
    8. When dropping them, drop the last pup first if you have to split them up.
    9. Once you drop the last pup, pull the converter out from under it, close the air off and drop it, then drop the front pup.
    10. Always make sure the Safety latch is engaged on the Pindle Hooks.
    11. Going down the road, do not let the pups wiggle a lot, if one drops off the pavement, you will probably lose them.
    12. Do not spend a lot of time looking in your mirror at them. you can tell if they are wiggling just by the way your tractor acts(sways)
    13. They will actually ride better than a 53' van.
    14. If you blow a tire or get on ice, they will be a lot more squirrely than a 53' van.
    15. Keep in mind that you will be pulling about 61' worth of trailer instead of 53'
    A lot of this you will be taught, some you wont.
    davetiow and blairandgretchen Thank this.
  9. blairandgretchen
    13,376
    71,892
    Dec 9, 2011
    South west Missouri
    Thanks justa driver. That pretty much covers it.
    justa_driver Thanks this.
  10. Jakethebrake99
    Jakethebrake99 Light Load Member
    103
    96
    Dec 16, 2011
    Heavy trailer always hooked first in the set. Turns are easier pulling a set, after hooking the set don't forget to turn the air valve on the dolly to the on position, visually check to make sure fifth wheel jaws are locked after pull test, carry an extra pigtail with you in case the one with the dolly malfunctions so you are not stuck with no lights on rear trailer...these are a few things that come to mind after pulling doubles for 5 years of my career
  11. justa_driver
    1,105
    817
    Apr 2, 2014
    Tennessee
    Oh and Make Sure your Safety Chains are hooked.
