Question? Is the ISX12 2015 engine a good engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 18 wheels hummin, Jan 13, 2022.
  1. 18 wheels hummin
    18 wheels hummin Bobtail Member
    27
    12
    Dec 8, 2014
    I drive a pete has almost 700,000 miles on it. Only been driving it a mouth runs fine check engine light for case pressure ( filter ?) high pressure fuel leak( fuel injectors?) Should i think about inframe. Or look for something else. Thanks
  3. rogermunn1
    rogermunn1 Light Load Member
    53
    61
    Dec 17, 2017
    NewBrunswick
    If it burns DEF then its not a good engine
    msh and 18 wheels hummin Thank this.
  4. 18 wheels hummin
    27
    12
    Dec 8, 2014
    No it use def pretty much like every thing else when it regen can tell needle moved can go 3 fill ups before adding def about 12 gals on. 2 100 gal tanks
  • Draft saved Draft deleted
