Questions about driving a truck/ tractor
Discussion in 'Questions From New Drivers' started by alone, Jun 27, 2014.
  1. alone
    alone Light Load Member
    I have a bunch of questions about driving trucks/ tractors. First question, as dumb as it may be, are the terms "truck" and "tractor" used interchangeably?
    One thing I've read a lot about is the shifting. Difficulty up/ down shifting, floating gears, and double clutching.
    What is the purpose of double clutching? Why can't you simply push in the clutch and hold it there until you complete the shift from one gear to the next, up or down? Is it because of how rapidly/ slowly the engine's rpm changes? Because of the close ratio of the transmission gearing?
    I understand there is a clutch break that is activated when the clutch is pushed to the floor. Is there anything that lets you know how far you can push the clutch in before activating the clutch break? Some kind of detent, or just a change in pedal pressure or something?
    I know how an automobiles clutch and transmission work, I haven't had any experience with a tractor/ truck though. I can say that once I learned how the clutch worked in the automobiles, it made learning to drive them much easier. It took the mystery out of it. It wasn't just a "push in the magic pedal, shift into a gear, let the magic pedal out and away you go". I learned why I needed to let the clutch out slower or faster, and why I needed to accelerate more or less depending on conditions. I think it would help me and possibly some others if the magic was explained.
  3. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Truck: carries its own load (pickup truck, straight truck, box truck)
    Tractor: worthless without implements (trailer, thresher, etc).
    Semi-trailer: semi-articulating trailer (there is load in front of the front pivot point -- the kingpin)
    You double clutch because truck transmissions are not synchronized. Car transmissions have synchromesh that matches input/output shaft speeds as you shift so there is no grinding. With a truck you have to match input/output shaft speeds by rev-matching to avoid grinding.
  4. SpiritWolf
    SpiritWolf Light Load Member
    192
    118
    Jul 10, 2012
    North Highlands CA
    #1. "truck" CAN refer to the entire vehicle including trailer. "Tractor" is just the cab section.
    #2. Double clutching is because 99% of tractors dont have a synchronizer (spelling?). That the bit the makes sure your gears are all spinning the same speed when you shift so you don't hear a loud crunch. Its a fragile part, and wont survive life in a truck. So we have to do it the old fashioned way.
    #3. Not one of the 3 trucks I ran had any sort or detent or other obvious sign that you had hit the clutch brake. After a while you just kind of figured out where it was on the pedal stroke. The ONLY time you use it anyway is when your shifting into gear from neutral at a stop. Going up or down the rest of the time a small clutch depression is all thats needed. The clutch brake is only activated when you put the clutch to the floor.
    Thats my best ""laymen's" description, and how ti was explained to me.
  5. 201
    201 Road Train Member
    12,277
    25,064
    Apr 16, 2014
    high plains colorado
    Hi alone, shifting is probably the biggest fear in new drivers. Check out the thread" First time on practice range,not so great", I went through the shifting dilemma with 2 other new drivers. If you still need help, let us know, BTW, there are no dumb questions!!!!
  6. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    Problem when looking for truck parts is there is no common word to use on google. Semi, kinda means 18 wheeler, but rarely do part manufactures use that word. Google truck, and you get pick up trucks. Truck is a strait truck, a pick up truck, an 18 wheeler, etc. Tractor is just the truck without the trailer. (or a farm tool) Dont google tractor parts or you will get a bunch of farm tractor site. I like the word semi, because its the word for big trucks.
    So to clarify, truck is the whole thing, tractor is just the tow vehical that doesn't have cargo.
    Cars have syncroes that make the motor side and gear side spin at the same speed as you engage the gear. Trucks dont. By double clutching, you sync the speeds so you can slide it into gear. You can also float which basicaly is adjusting motor rpm perfectly to match the speeds on your own. Some single cluch out of gear and float in. Most truckers eventually learn to float to save their left leg. In some cases its hard to get it out of gear (like a steep uphill, or when its cold). that when i single cluch to nutral then float in. Cluctching to nutra then clutching again gives you more room for error getting it in the next gear.
  7. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Double clutching is a useless as Satellite navigation on a Locomotive. I ahve never done it in 4.3 million miles. Drive like you have an egg under your foot. Drive a truck like its a loaded weapon and could go off at any time.
    Follow that car, Godzilla - and step on it !
    "semi" retired Thanks this.
  8. 201
    12,277
    25,064
    Apr 16, 2014
    Hi Passin Thru, that's pretty funny, I too rarely used the clutch. For beginners, it is a good way to understand the basics, but get's old in a hurry. Sometimes when splitting a gear, I'd rest my foot on the clutch, to take the pressure off the driveline for a cleaner split, but starting and stopping, that's it.
  9. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    Semi comes from the fact that the trailer only has one set of wheels. It is a semi trailer not a full trailer.
    Everything else has been covered.
    A truck driver is the under paid over worked man who sits in the tractor. It is called a tractor because we all want to retire to a farm but our wives want to live in New York City.
  10. Night Prowler
    Night Prowler Medium Load Member
    549
    275
    Aug 9, 2013
    Temple, Texas
    YOUR BOY E THE TRUCKER ( on you tube ) has a very good shifting video. you can find most anything on you tube.
  11. Night Prowler
    549
    275
    Aug 9, 2013
    Temple, Texas
    I still love that show ! pettiecoat junction ! See I told you, you can find just about anything on youtube !
