I do almost exclusively drop and hook loads. The account I am on tends to load well over 40k lbs 90+% of the time.
Every now and then I find a trailer that is sitting several inches too high. Cranking down a 40k+ lb trailer several inches is highly annoying.
I have considered using a couple 2x6s a couple feet long, to make two short, low ramps that I can roll the truck drives onto while backing under the trailer in order to get high enough to get a good hook.
Has anyone here tried anything like that?
If so, how did it work?
Questions for others that do lots of drop and hook
Discussion in 'Experienced Truckers' Advice' started by Farmerbob1, Oct 5, 2018.
Page 1 of 6
Just put a piece of lumber across your frame or on your 5th w the bags dumped and put air to the suspension while your under the front of the trailer and after it lifts crank the dollies down, dump the air and lose the blocks.
May have to do it twice.Last edited: Oct 5, 2018
MBAngel, LoneCowboy, Farmerbob1 and 8 others Thank this. -
Crank the gear handle in low gear so it is less effort.
KB3MMX and Suspect Zero Thank this. -
Lonesome and Farmerbob1 Thank this.
We have to spot heavy generators for TV broadcasts, which have to be level front to back. Lots of times we have to use the 4x4 between the 5th wheel and pin plate with dumping the air suspension and lifting them. When we are done you can almost walk underneath in some extreme locations.
Farmerbob1 Thanks this. -
Rideandrepair Thanks this.
I see, misread on the too high part.
88 Alpha and Rideandrepair Thank this. -
I once rammed the side near landing gear as trailer was way low it didn’t matter old junk trailer anyway it worked. The guys I worked with were freaking out but we had to go!!!
Page 1 of 6
