rapid air pressure loss - engine off - 07 Volvo 780
Discussion in 'Volvo Forum' started by neverhome, Oct 30, 2011.
  1. neverhome
    neverhome Bobtail Member
    21
    5
    Oct 30, 2011
    ywg
    Right now, this truck is basically just sitting in my yard so I have the time to correct a couple of things if needed.
    This is what happens:
    1. Bobtail, little or no wind
    2. Build air to 130psi
    3. Turn off engine and wait 1 to 2 hrs
    4. Air pressure has dropped to approx 60psi
    5. Do not restart engine, wait as much as 24 to 48 hrs or so
    6. Air pressure does not drop much if any further, remains near or slightly below 60 psi for an extended period of time.
    Somehow, I wouldn't expect this to be normal behavior. Correct? Suggestions as to where to look?
    Thanks for any help.
  3. v6killer
    v6killer Medium Load Member
    448
    122
    Dec 6, 2010
    ChicagoLand
    I would start looking at the air level system on the back axel, Volvo has an up dated part for the system. four air lines down to two. After volvo replace the leveling system on my truck ( 110 .00 for the part plus labor ) 90% of my air leaks were gone.
    neverhome Thanks this.
  4. neverhome
    21
    5
    Oct 30, 2011
    ywg
    Thanks for the suggestion. That sounds like it might be worth doing anyway.
  5. gabbys777
    gabbys777 Bobtail Member
    14
    Feb 10, 2010
    Houston, Texas
    I had the same problem. It turned out to be a air valve located on the frame above the batteries
    scatruck and neverhome Thank this.
  6. 7060
    7060 Light Load Member
    55
    5
    Oct 2, 2010
    If your loosing that much air that quick just walk around the truck listening, the leveling valve you can push down on the arm after the bags fill to stop it from leaking in sometimes. While were talking about air leaks and I hate to hijack your thread but I have a valve leaking behind my engine oil filters on my d12, what would that be?
  7. bossboy2
    bossboy2 Light Load Member
    264
    60
    Aug 20, 2011
    Houston, TX
    Mine is being fixed tomorrow. Granted it's 2005 but the company I'm leasing on with won't pass it until there are no air leaks. My leak is the air leveling valve on the front airbag, on the front drive axle...driver's side. BTW, they found it with a spray bottle and soap/water mixture...make sure the spray bottle is of the industrial type that will shoot about 5 feet or so.
    neverhome and davidtruckervan Thank this.
  8. neverhome
    21
    5
    Oct 30, 2011
    ywg
    I will look there.
    Thanks.
    Nothing that I can hear, even with the truck shut off. I agree, tho, that much air leakage should make a sound. But it doesn't seem to.
    What's really puzzling to me is that the air loss essentially stops once it gets down to approx 60psi. A valve that trips and isolates the leaky section?
    This might help finding the leak and the part to replace.
    Thanks.
    Another good suggestion about where, and how, to look for the leak. Hope there is only one air leak.
    Thanks.
  9. neverhome
    21
    5
    Oct 30, 2011
    ywg
    For anyone who might be interested, the air loss was reduced to approx. 1/4 of what it was by:
    =replacing two leaky fittings at the foot valve
    =replacing and sealing the threads on one leaky fitting at the air drier
    =replacing both cab air bags
    =plugging one broken air flow valve line in the driver's seat
  10. xiipercent
    xiipercent Medium Load Member
    456
    129
    Mar 19, 2007
    I'm tackling these issues today.
    what i'm curioius about is what i've heard refer to as the wet tank and dry tanks. Does that apply to the volvo780?
    what I know for sure: the front air tank(towards the steer tire) has a hairline crack. This has been the case for over a year. I've been told that it's the accumualtor tank. The two other tankshave no known leaks.
    The new problem just started this week. i'm losing all my air in about 3-5minutes.
    When the truck is running, it builds to 120-130, then all is ok(though i think the air pressure overfill release is cycling more frequently) every 90 seconds when rolling down the hiway bobtail.
    the way i'm led to believe how the system works is this- the accumulator tanks fills first, then fills the other two tanks, with no way for the two tanks to drain into the accumulator.( that's why I don't think the accumulator tank is the issue) it's a $550 tank to replace(not including labor)
    when i turn off the truck, it's the accumulator tank that's making the most noise, so it's hard to identify other leak noises.
    Any input is appreciated.
  11. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,643
    Oct 11, 2010
    Borispol, Ukraine
    the last time I got the same issue it was ISX turbo actuator. It is connected to front brake tank and when engine is on it dumps air.
