Rear ended gauges don’t work.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lowboy265, Sep 24, 2020.
  1. Lowboy265
    Lowboy265 Bobtail Member
    4
    Sep 23, 2020
    My gauges on 2008 T-800 don’t work. Changed sensors. But gauges still don’t work any ideas.
    Trucking Jobs in 30 seconds
  3. '88K100
    '88K100 Light Load Member
    195
    301
    Aug 23, 2020
    Likely the wiring itself. Trace wiring from sending unit to Guatemala. I drive company truck, rear end gauges have not worked in years on my truck,,,lots of exposure to salt and ice.
  4. Lowboy265
    4
    Sep 23, 2020
    Yes I am thinking it’s in the wiring. Were working until six months ago. I haul heavy permit loads. So it is nice to have them operational.
  5. Loaderlou
    Loaderlou Light Load Member
    286
    104
    Feb 24, 2014
    I recently found my problem with both rears. I was tracing my wires when I first got the tractor about 14 years ago with one of those sharp pointed test lights. The kind you have to pierce the wire coating to touch the wire for a signal. Well I never sealed the wire and it corroded. So just as 88 says. Start at the sender and work backwards. I don’t think you’ll have to go all the way to Guatemala because the harnesses are made in Mehico, but maybe in Southern Mehico which is pretty close to Guatemala
  • Draft saved Draft deleted
