Reefer, Dry Van, or Flatbed?
Discussion in 'Questions From New Drivers' started by Sam Hell, Aug 14, 2012.
  1. Sam Hell
    Sam Hell Light Load Member
    127
    79
    Aug 12, 2012
    For those that don't know, I am in the "thinking about it" stage of a career change.
    I have been doing some research on various companies and options to get my foot in the door but now I have other questions and they're about trailers.
    I can read company websites all day long about their equipment (trailers) but I want to hear it from YOU, the driver, that has to deal with the equipment on a daily basis.
    Reefers: I assume that you have to monitor it every time you stop, but do you have to make adjustments to the settings during the trip or do you just set it and go? Do you have to perform maintenance on it during the trip? Is there a lot of touch freight with reefers?
    Dry Van: Is there a lot of: touch freight? LTL stops? Drop n hooks?
    Flatbed: I know you guys probably have about the most physical job in the trucking industry as far as load securement goes but is there anything else to know about pulling flatbeds? Are your loads ever as tall as a dry van?
    I know these are very noob questions but I would appreciate any info :)
    Thanks and have a great day
  3. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Honestly a lot of our recommendation about what trailer to pull would be based on where you would call home. But first, flatbed involves some work and skills that are unique unto themselves. For those who appreciate a "good tarp job" and a challenge, flatbed may be a good consideration, depending on where you live and want to work. Otherwise, vans are dime a dozen and they flood the market a bit more than reefer. Reefer guarantees you'll deal with a lot of grocery store warehouses which can be a problem sometimes for loss of time and hassle. However, meat hauling is always steady and the miles are usually better than average with reefer. The monitoring of reefer status is not an issue worth considering, but additional trailer washouts between loads can be time consuming if loading at a shipper that want's it washed out before you arrive.
    A reefer is the most steady work, in spite of overall economy, IMO but my reefer experience and recommendation is based on a better than average outfit that does not hire new drivers. So consider my advice at your own peril. But I have pulled flatbed for a few years and van for 10+ years, as well.
    sly1 and Sam Hell Thank this.
  4. Sam Hell
    127
    79
    Aug 12, 2012
    Thank you STexan!
  5. pete1
    pete1 Heavy Load Member
    Reefer- make sure you have comfortable clothes and plenty of hobbies as you will spend most of your time sitting around waiting to get loaded/ unloaded.
    Dry Van- go on a diet NOW before you even begin working!!!!!
    Flatbed- snow,rain,mud, ice,sweating your ### off.
    Sam Hell Thanks this.
  6. silentlysailing
    silentlysailing Light Load Member
    244
    97
    Mar 21, 2010
    DFW, TX
    From my experience pulling reefers you have to be comfortable with night driving too. Depends on company policy as to the amount of work. Like I was doing multiple stops for a while, and you had to send your temps in on the quallcomm at every stop. Then mine had 2 bulkheads that I had to wear gloves not to burn my fingers on. More dealing with lumpers/driver unloads. I agree with the tendency of longer time at shippers and finals too.
    BTW its fairly easy to make sure the reefer is running right as you have a status light that is visible in your mirror.
    Dry van, easy sleazy.
    Flatbed I can't comment on as I've never done flatbed.
  7. pete1
    One good thing about being a Flatbed driver; since nobody thinks you can back up, you usually dont have to!!!!
    You can even get away with nosing into parking spots!!!!:biggrin_2559::biggrin_2559:
  8. freightrunner
    freightrunner Heavy Load Member
    722
    182
    Mar 25, 2012
    Georgia
    If you're buying a trailer buy a reefer... You can haul frozen and dry goods..
  9. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    I chose reefer for my reentry to the business based solely on the economy... people still have to eat. There is some waiting especially with Produce and meat loads. I waited 12 hrs on blueberries last week in California. 3 pallets, but they were late getting there and the had to cool to the right temp. It happens.
  10. cuzzin it
    cuzzin it Road Train Member
    3,491
    8,688
    Jan 19, 2008
    Berea, KY
    i love hauling produce..... However i'n doing flat at the moment, and starting to like it... no tarps
    if i had it all over to do again, i might go flatbed.
