Reefer or Van?
Discussion in 'Questions To Truckers From The General Public' started by CrazyAzzCowGurL, Aug 18, 2007.
  1. Please tell me what exactly is the difference between a Van and a Reefer. I was just looking at pictures under the description and they appear to be one in the same???
    When I think Van --- I think Van. Not what they were showing.
    Any clarification would help as I am searching the load boards for a friend of mine.
  3. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    A reefer is a temperature controlled van used to haul mostly food products that need to be either refridgerated or frozen.
    A van is just the regular enclosed trailer with no temperature controls.
    LB
  4. RNGTransport
    RNGTransport Light Load Member
    134
    19
    Jul 13, 2007
    Allendale, MI
    A van is a dry box and a reefer is insulated and has a refrigeration unit on the front that can either cool or heat the product being transported. They look similar expect when you look at them from the front and a van is not a really a van like a freightliner sprinter or a Pontiac Montana, at least not in the truckers vocabulary
  5. Thank you very much for responding so quickly.
    So - then. If there is no difference than refrigeration, if you have a reefer and there is a load posted for a 48' van can you take it?
  6. RNGTransport
    134
    19
    Jul 13, 2007
    Allendale, MI
    Yes you can but you need to check the weight of the load as you may overgross as an empty reefer is heavier as than an empty dry van
  7. Thank you again for your quick reply.
    I can't find the link to the terms of service so I am not sure if this question is allowed, but I am going to ask it anyway-
    Thoughts on which load board is the best?
  8. RNGTransport
    134
    19
    Jul 13, 2007
    Allendale, MI
    Really cant help there but might want to give a little more information on what your trying to do. If your talking from an O/Os stand point or someother type of opertation
  9. CrazyCowGurL
    CrazyCowGurL Bobtail Member
    Arcadia, Florida
    O/O standpoint.
    Just trying to keep some good ole' boys around here on the road.
  10. RNGTransport
    134
    19
    Jul 13, 2007
    Allendale, MI
    Really cant help you on the load boards since I dont use one but if they dont mind running all 48 states they might want to check into landstar as I hear they have alot of freight and they drivers can choose the loads. But again I dont personally use a load board so I dont have much information on them.
    From my understanding you have to actually apply and register with Landstar but again I dont know alot about them except the few things I have read on the forum
  11. CrazyCowGurL
    Arcadia, Florida
    Thank you for your input. It is greatly appreciated.
