I rented a 28' trailer that I will be loading with the contents of my garage to move cross country. Freight line is Old Dominion, I asked them how much weight I could put in their trailer, they said they go by volume not weight and that they don't weigh the trailers. I am guessing that I could put 30,000 pounds in the trailer, but I don't want it to end up stuck in a weigh station somewhere because of me. Anyone know how much I can legally put in one of these trailers? I have a pallet scale so I wont be guessing at how heavy I am loading it, just need to know where to stop.
Rented trailer with no weight limit??
Discussion in 'Trucking Industry Regulations' started by mamllc, Aug 7, 2018.
Is the trailer single or tandem axle?
Typical 28 ft pup freight trailer around 1000#/ft. So yeah 30k should be ok. Every trailer has weight limits.
An empty set weighs about 28k with a single screw day cab, obviously another approx 2k with a twin screw sleeper. So figure about 25k in each trailer.
Jazz1 Thanks this. -
If they say no weight limit, get it in writing and load that sucker up! Too many variables to guess accurately. I am sure at 28' it's a single axle which means you can have 20k lbs on the trailer axle, if a 3 axle truck is pulling it, it can have 34k up front. There is the issue of trailer empty weight, axle setup, truck weight, they are most likely gonna pull it as a set of doubles for any real distance, you wont know what the other trailer weighs for gross. When I pulled pneumatics, single axle day cab with lightweight bulk tank trailers, we were loading up to about 56k legally with a gross of about 79980 or so. That's roughly 28k per trailer. I'm gonna have to agree with about 25k in a van.
I never know my trailer weights, my manifest weights are pulled out of thin air
My Twin screw day cab with tandem 32’ lead and tandem 28’ pup
137,000 gross
Beer lead/meat pup -
What are you loading that is 30k? The total contents of most 4 bedroom houses with a 2 car garbage. Barely come out to 30k and they fill up an entire 53 foot high cube trailer floor to ceiling
I want to get as much in the trailer as I can, but don't want problems out on the road. What happens if the truck ends up at a weigh station and is overweight? Do they fine the driver/carrier and let the truck go, does my equipment get stranded at a weigh station in the middle of the country? -
30,000 is 48 foot 53 foot trailer stuff.
I don't think you can stuff that much into a pup.
There should be a data plate near the front that will tell you what the trailer can carry in terms of gross weight.
I don't know what tractor you are towing with so, two axle or single axle? etc. I don't know if the trailer has one axle back there or two. (Probably one)
Then you need to break out the length, weight chart against your total axles, find the tare of both the tractor and trailer at a CAT scale weigh it. Then you will have a good idea of the gross you can be at. The difference will be what you can put into it.
Now in my time Ive hauled seacans at 20 foot boxes container with massive amounts of weight. And this is with a three axle tractor and a three axle chassis and STILL over weight, even with a 99K permit. Such a massive weight introduces serious driveablity problems.
30K? I'll probably split it and run two loads at 15K each. That way you will be relatively safe.
