Repaired transmission and output shaft 3 months ago. It's BROKEN now (it happens)Thanks for any help
Discussion in 'Freightliner Forum' started by Lion220, Jul 25, 2020.
  1. Lion220
    Lion220 Bobtail Member
    11
    4
    Nov 22, 2019
    Repaired my transmission not too long ago. Just the other day it left me stranded on the road. After paying an arm and a leg for a tow my mechanic told me there was a problem with the tail of the transmission.
    I'm not very familiar with the working of said tail (output shaft in English?) But he did say some of the synchronizers were broken. Could anyone explain to me what those do and why those could break? None of my mechanic friends have been able to figure it out. Thanks a lot in advance.
    The transmission is an Eaton fuller regular 10 speed and the truck is a 95 fld 120
    Below is a picture of the broken part.
    Trucking Jobs in 30 seconds
  3. QUALITYTRUCK
    1,434
    1,205
    Jun 14, 2009
    romulus,mi
    More than likely you were not able to get Hi/low range? Are you sure that it wasn't your input shaft that you had repaired 3 months ago? That is a more common repair.
    Lion220, p608 and spsauerland Thank this.
  4. Claytonbigsby
    Claytonbigsby Bobtail Member
    29
    84
    Mar 31, 2019
    Broken pins on synchronizers are usually from tortional vibration. Can you look at your driveshaft to tell if it was phased correctly after the original repair?
    Lion220, QUALITYTRUCK and spsauerland Thank this.
  5. Lion220
    11
    4
    Nov 22, 2019
    Thanks for the replies. I'll look into it. The shop lowered the whole transmission and tomorrow it'll be up. I've been suspecting that the shop placed the driveshaft wrong. Will have to see tomorrow, thanks
  • Draft saved Draft deleted
