Replaced head and gasket still smoking out blow by
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mad dog logistics llc, Aug 23, 2019.
  1. Mad dog logistics llc
    Mad dog logistics llc Light Load Member
    97
    19
    Jan 13, 2014
    I just replaced the cylinder head and gasket. The head was cracked from my driver over heating the motor. We got the truck running today and noticed white smoke coming from the blow by tube. Is it possible that the motor is burning off antifreeze that was left behind in the old oil? I changed the oil. I did the bottle test there are no bubbles and the motor is hot, tomorrow I will pressurize the coolant system to see if it holds. A gut told me that it could be coolant that was left in the motor from when I drained the oil? Any one have any ideas?
    2000 Cat C-10
  2. Intothesunset
    Intothesunset Road Train Member
    2,298
    4,821
    Apr 15, 2019
    truck
    Could be your piston rings, or liner issue?
    Diesel Dave Thanks this.
  3. truckdriver31
    4,280
    4,298
    Sep 18, 2013
    did you get new head bolts.
    Intothesunset Thanks this.
  4. Diesel Dave
    5,043
    5,836
    Jan 20, 2010
    Hesperia, Ca.
    Times 2
  5. swaan
    swaan Road Train Member
    2,790
    3,911
    Jul 12, 2009
    BC canada
    Depending on how hot he got the engine the tension on the rings could be a lot less now. Or even scored liners.? Nothing good comes from overheating an engine, especially if he lost all the coolant also.
  6. Mad dog logistics llc
    97
    19
    Jan 13, 2014
    Yeah he added 3 gallons of fluid. A hose had a leak. The oil had antifreeze in it an oil pressure had dropped I was hoping it was burning off old coolant in the system, pressuring it now to see if it holds.
  • Draft saved Draft deleted
