Reusable engine air filter
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 18-Rtransport, May 14, 2021.
  1. 18-Rtransport
    18-Rtransport Bobtail Member
    I am having a problem finding a reusable engine air filter for my 2018 International with a Cummins ISX motor. Does anyone know where I can get one?
    Trucking Jobs in 30 seconds
  3. larry2903
    larry2903 Medium Load Member
    673
    686
    Oct 18, 2009
    On the trails
    Why would you want to? I know a guy that ran the one that Rutherford used to advertise and he said never again. Main reason was the up front cost and mess of having to clean and re-oil the element for the reusable filter.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    3,370
    4,610
    Aug 26, 2014
    I suppose you know factory filters are not supposed to be cleaned out. Blowing high pressure air through them can blow a hole in them. Then you are sucking dirt straight into the engine. On some farm trucks ( serviced annually ) we roll them while tapping on them on the floor. then blow them out with low pressure air. Those trucks run under 5,000 miles a year but we still replace them every three years max.
    Around a cement plant is different. That stuff can build up but the truck runs fine until it rains. Truck brand A did fine. Truck brand B needed filters every 8 months.
    If you are pounding the road 150,000 miles a year just replace it every year or two. Increased mileage will surely pay for it.
    Just my opinion.
  5. bavarian
    bavarian Medium Load Member
    627
    627
    Feb 13, 2014
    Winnipeg
    Fleet air filter. After 8 years, I need new pads.
  • Draft saved Draft deleted
