Right turn signal not working on chassis
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CG514, Sep 23, 2020.
  1. CG514
    CG514 Bobtail Member
    I've got a problem with right turn signal not working on any chassis that I have used the past couple of days. I tested the pig tail that connects to the chassis and did not get a signal on it like I would for the left turn signal. I then tried it from the plug coming from the cab and also no signal from the tester on right turn signal. I tried to see of i could open up to see if there was a loose wire but couldn't figure out how to open it without having to cut it. I uploaded pictures to see what im talking about. I also checked fuses with the tester and all were good. Can I open up this plug in the pictures to check the wires or will that mess it and will have to replace it? Is there somewhere else i can check before opening up the plug in the pictures. Any help would be greatly appreciated.
    Trucking Jobs in 30 seconds
  3. Smellfunny
    Smellfunny Heavy Load Member
    991
    458
    Jan 28, 2012
    South Carolina
    Not sure what truck that is but you should be able to follow that end back a little ways (not far) and it will unplug there.
  4. CG514
    It's a 2013 kenworth t660
  5. Smellfunny
    991
    458
    Jan 28, 2012
    South Carolina
    I have only had issues with that plug on International trucks but if they are similar and my memory is right it should go down about a foot or so and unplug there. But it may be different on KW.
  • Draft saved Draft deleted
