Are the road king mics really worth the 60 bucks or whatever they cost? Just curious cause the guys that tuned, peaked, and did the finals in my radio said I should get one. I cant turn my mic gain all the way up with my wilson mic right now and the guy said with a road king I should be able to turn the gain all the way up? Thanks for any info.
Road King Mic's
Discussion in 'CB Radio Forum' started by brinkj23, Mar 7, 2009.
Page 1 of 4
Well the RK 56 and the Astatic 636 are the best mics you can get and are alot cheaper on the net then in the truck stops. I can get Astatic 636 mics for under 30.00 on the net.
Another better then stock mic is the Skythumper ST 65.
Stay away from powered mics.
Oh and why is it you can not turn your mic gain up? Is it because it is squeeling due to Talkback? If so then turn the TB off or get it taken out of the radio. It is not needed unless you like to listen to yourself.rabbiporkchop Thanks this. -
I use an RK. Have had it for many many years.
I never turn the mic gain over half way. What's the point? Other than over modulating. If your radio is tuned right to begin with....cranking the gain shouldn't be on the list of things to do.
People hear me fine, say my radio is loud and clear.Grumppy Thanks this. -
Yeah I get out fine and peoplesay my radios loud and clear only got the mic gain up half way. I like having the talk back in my radio so I know im getting out and not squeeling or sounding like crap. But when I turn the gain up past half way it squeels real bad when I key up. Just wondering if I should get a RK or just stick with the wilson I got, think i'll notice a difference? Thanks
I say if what you got works. Leave it alone. That's were most drivers mess up. Constantly tinkering with a radio, until it's totally screwed up. When there was nothing wrong with it at all, to begin with. -
I have a RK mic and an Astatic and prefer the Astatic mic without a doubt using on a Stryker SR 490 hp
copper electronics has a pretty good price on mics.a noise canceling mic is a must to me.look around you can beat 60 bucks for it.as far as your mic gain goes your radio man should have set it so that it does not have to be cranked up.
Justr because the talk back sounds good, it doesn't mean the radio is sounding good on the other end.
A noise canceling mic is a must have item, especially if you run straights. Love my Astatic 636L. Got rid of the background noise and much clearer than the stocker on my Magnum. -
You can get Astatic 636L's on ebay all day long for $25.
Page 1 of 4
