Michigan to New Hampshire
10’6” W / 98’6” L / legal H / 85000#
90 - 91 ?
80 - 81- 84 - 91 ?
Routing help
Discussion in 'Heavy Haul Trucking Forum' started by brianwhenderson, May 22, 2018.
SavageMuffin and nax Thank this.
80 and 90 are toll road. Don’t know the size limit...but the common OSOW route out of eastern Michigan is US23. I’ve never been on the Ohio turnpike with an OSOW. I’m thinking they will put you on US 20. Be sure to doublecheck the Ohio and Pennsylvania OSOW provisions (which your permit will tell you that you have to have with you for your permit to be valid.).
Well, I checked. You will be able to run the Ohio turnpike. You will have to buy your permit at the toll booth.Last edited: May 23, 2018
snowman_w900 Thanks this. -
Max width on the ohio turnpike is 10ft length is 75ft and legal height 90k lbs, most likely ohio will route him down to us20 across. Thays usually theway they route os
Oxbow Thanks this.
