RPM's with 3.36 rears and EF10OD tranny
Discussion in 'Ask An Owner Operator' started by I3IGBIRD26, Dec 1, 2021.
  1. I3IGBIRD26
    I3IGBIRD26 Bobtail Member
    34
    7
    Jun 25, 2021
    KW T680 with 22.5 tires (about 84 inch diameter), 3.36 axle ratio, paccar 400hp engine. Wanting to roll at about 65mph between Florida and Texas. Anyone experienced this or similar setup that can tell me what the rpm's run at this speed? Thanks
  3. NYStarcar
    NYStarcar Light Load Member
    110
    250
    Oct 6, 2020
    Depends which version of the 10 speed you go with for a final overdrive ratio.
  4. scoobertdoo
    scoobertdoo Medium Load Member
    628
    970
    Nov 11, 2020
    My Pete might be a 3.05, I turn 1300 at 65ish on a Eaton 10
  • Draft saved Draft deleted
