RTLO16610B
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ed W, Apr 5, 2020.
  1. Ed W
    Ed W Bobtail Member
    23
    6
    Jul 29, 2012
    Western NY state
    I have a RTLO16610B (super 10) remained with a new shift tower! shift lever is in neutral but it is in gear will not come out
    jamespmack Thanks this.
  2. jamespmack
    135,827
    Unbolt shift tower and reset it. It's not in the shift rails. Have someone hold shifter while you guide the base. It takes "feel" to do it by yourself.
    25(2)+2 and 650cat425 Thank this.
  3. Ed W
    Ed W Bobtail Member
    23
    6
    Jul 29, 2012
    Western NY state
    After I put the new tower on I went through all the gears then went for a short drive shifted up and down good the next day started the truck ran through the gears and then this happened
  4. jamespmack
    135,827
    Well it's either wrong tower and it came out. Or something came apart on shift rails.
    I would remove tower, verify shift rails are in neutral and start it to see it's in neutral. If so reset tower and try again.
  5. Ed W
    Ed W Bobtail Member
    23
    6
    Jul 29, 2012
    Western NY state
    This transmission did this and I rebuilt my old tower it did same thing now I put a new tower from Eaton on it and doing it still
  6. jamespmack
    135,827
    Ok so your saying you have eliminated the shift tower then, right. Only other place is top cover then.
    Ed W Thanks this.
  7. jamespmack
    135,827
    When it does not come out of gear, have you removed tower and checked to see were the rails are at? Are the rails in neutral?
    Ed W Thanks this.
  8. Ed W
    Ed W Bobtail Member
    23
    6
    Jul 29, 2012
    Western NY state
    I have to wait until tomorrow I think this time they are coming to see it first hand you are saying what I have said from the start and they don't want to admit that they might have been wrong
  9. jamespmack
    135,827
    What did we find?
    But I dont recall any RTLO Super 10?
    Ed W Thanks this.
  10. Ed W
    Ed W Bobtail Member
    23
    6
    Jul 29, 2012
    Western NY state
    They're telling me that the stub shaft was not in the rail but can not tell me how I drove it about 97 miles before it locked up
  • Draft saved Draft deleted
