Satellite Radio and stereo connections
Discussion in 'Roehl' started by meistreguy, Aug 7, 2012.
  1. meistreguy
    meistreguy Bobtail Member
    29
    6
    Aug 6, 2012
    I was just wondering if any of you have satellite radio in your truck. Do the stock stereos have an auxillary input which will make it easier and also if it does not, did you connect it using FM direct connect to the antenna on the back of the stereo (I have done it this way) since if you just use the FM transmitter sometimes you will get bleed-over in the larger cities. If you did use FM direct connect, did you have to get maintenance to pull out the stereo for you to hook it up.
    I should be starting orientation on Aug 13th if nothing delays me. I am an experienced driver and will be doing van in the Texas regional fleet.
  3. inkeper
    inkeper Road Train Member
    1,440
    1,059
    Jan 30, 2011
    Texas
    The newer trucks will have the aux port, the older ones most likely will not. I have used all three ways, FM transmit, direct antenna connect, and aux port.
    There is a tool for each type of radio to release it from the dash. I was lucky enough to be friendly with the shop guy, he had spare tools for the radio I had and gave me what I needed when I said I would do it myself. They like that sort of thing when the hardest they have to work is give you something.
    Sorry, I'm a Swift guy that happened to see your post on the new post feed.
    meistreguy Thanks this.
  4. coopnp
    coopnp Road Train Member
    1,039
    454
    Oct 9, 2011
    Orlando, FL
    But he's right new trucks have aux port old ones mostly do not but you could get lucky. I use the aux now and the fm way when the aux wasnt avaiable. Ive heard of other drivers using a fm transmitter. Ive never went that route or tried that way but I'm pretty sure maintenance shop guy could help you out.
  5. spydertrucker
    spydertrucker Bobtail Member
    7
    Aug 8, 2012
    how new of trucks are we talking 2000 on up or 2012 up???? do freightliners and internationals have the same ports on front of radio???
  6. coopnp
    1,039
    454
    Oct 9, 2011
    Orlando, FL
    yeah i trained in a 2010 cascadia and I have a 2012 prostar now both have aux ports in the front. The freightliner columbia I had, had a aux port too but was damaged by another driver and replaced with a radio without one. Majority of the fleet is 2010-up slowly but surely getting rid of the 2006-2007's
  7. GunzFlatbedder
    GunzFlatbedder Medium Load Member
    443
    103
    Nov 28, 2008
    Marshfield
    i have a sirius with the direct connect cable getting rid of....have to hook up in txas area
  8. QuietMike
    QuietMike Medium Load Member
    371
    162
    Oct 21, 2009
    NE Ohio
    Both of my columbias have had the aux ports. My satellite radio is hooked up that way.
  9. hindsy
    hindsy Road Train Member
    1,489
    516
    Mar 23, 2010
    USA
    Aux is simply better and none of that annoying bleed thhru. I hated that and really it kinda defeated the purpose a bit...
  10. coopnp
    1,039
    454
    Oct 9, 2011
    Orlando, FL
    My power cord on my xm radio doesn't work anymore. The truck I have has satellite ready capability. Hindsy u talking it bleeds through and better off getting direct connect for the auxiliary port set up like I had b4?
  11. T-Lady
    T-Lady Medium Load Member
    368
    178
    Feb 20, 2012
    Wautoma, WI
    my 2012 Prostar+ has a Sirius ready radio. I just called Sirius and had them activate it. It can be de-activated whenever I get booted from the truck. This way, I needed no extra hardware, didn't have to remove the stereo, etc. Keep it simple.
    skyviper73 Thanks this.
  • Draft saved Draft deleted
