Scale weight
Discussion in 'Questions From New Drivers' started by VolTrucker1369, Apr 13, 2021.
  1. VolTrucker1369
    VolTrucker1369 Bobtail Member
    Apr 13, 2021
    I weighed my truck at a CAT scales. The readings were 13000 steers, 19,263 drives, 23,849 trailer. Could that steer reading even possibly be correct?
    truckdriver31 Thanks this.
    Trucking Jobs in 30 seconds
  3. SoulScream84
    1,447
    7,337
    Mar 21, 2020
    Yes, it depends on where your 5th wheel is setting. The previous truck I was running I typically ran at 13,100 on the steers. Just make sure your axle/tires are made for it.
  4. VolTrucker1369
    Apr 13, 2021
  5. slow pok
    slow pok Light Load Member
    86
    129
    Oct 27, 2013
    lizela ga
    The way u pop your brakes have a big effect on scale readings. I always stop then let of the pedal then pop them
    slow.rider and truckdriver31 Thank this.
  6. truckdriver31
    5,965
    6,709
    Sep 18, 2013
    yes. your trailer is picking up on your fifth wheel. this in turn pushes down on the steers
    Trucker61016 Thanks this.
  7. truckdriver31
    5,965
    6,709
    Sep 18, 2013
    if air bags. leave red nob in
  8. Long FLD
    Long FLD Road Train Member
    4,814
    14,800
    Mar 4, 2015
    Fairmont NE
    That’s not how air bags and leveling valves work. If the trailer was in fact lifting up the drives as you suggest then the leveling valve would constantly be dumping air to return the truck to the proper ride height.
    I’m 34k on my drives and 43.5k on my trailer and it’s not “picking my drives up”.
    Bean Jr., truckdriver31 and slow.rider Thank this.
  9. Roberts450
    Roberts450 Road Train Member
    2,091
    3,162
    Feb 6, 2016
    He means when the trailers auto dump the bags when setting the brakes. The locked brakes on the trailer will cause the trailer to push forward and raise the front of the trailer transferring weight off the drives and to the steers.
    It gets really interesting watching me scale a loaded tanker. Trucks rocking back n forth 6-8” yet the scale is rock solid steady on the read out. But if I set the tractor brakes it will take 15 minutes for the scale to settle.
  10. Long FLD
    4,814
    14,800
    Mar 4, 2015
    Fairmont NE
    Oh I gotcha. Yeah I never set the trailer brakes unless I’m unhooking so all that auto dump stuff is foreign to me. Sometimes I don’t comprehend what I’m reading. Lol.
    Roberts450 and truckdriver31 Thank this.
  11. slow.rider
    slow.rider Road Train Member
    1,080
    2,718
    Apr 4, 2017
    NYC
    I don't pop my brakes on the scale. After all, they don't want you doing it on the scalehouse scale either. May as well see what they see. Your brakes aren't popped while you're cruising down the highway, and that's ultimately the number they're after. In a manual you can shut off the engine with it in gear to keep it in place. The scale should be flat enough that you wont roll anyway, unless there's little tire ruts forming on it, but those should only pull you a few inches until you settle next to the mic, where everyone stops.
  • Draft saved Draft deleted
