Scales
Discussion in 'Ask An Owner Operator' started by Bernard D, Aug 5, 2020.
  1. Bernard D
    Bernard D Heavy Haul Member
    104
    27
    Jun 27, 2020
    Oregon DOT officer told me not to use cat scales,use their scales when i come,across a closed scale to calibrate my truck so to speak .
    T/False?
  3. kemosabi49
    10,003
    41,447
    Jan 13, 2013
    SW Arkansas
    Don't know about that. But what happens if you bypass that Cat scale and then the state scale you were going to check your weight at is open? And your weights are screwed up? Then you are too.
    ChevyCam, 401-Alex, Roberts450 and 9 others Thank this.
  4. SteveScott
    SteveScott Road Train Member
    4,897
    16,803
    Nov 10, 2015
    I think they were yankin your chain. :As has already been mentioned, what if the scale house is open? Oregon is nice in that respect that they have a lot of rarely used scales where you can weigh a load, but they can be open when you least expect it.
  5. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,567
    Dec 30, 2017
    Coal Town
    It is Oregon, Look what happened to Portland. I think they are messing with you
  6. abyliks
    abyliks Road Train Member
    3,052
    6,850
    May 2, 2010
    ludlow MA
    I’m sure they would, they can’t make money off you if you go back and go across theirs legal, well actually I’m sure they will, it will just be for something else.
    I have tractor/trailer load guages on my set up so I don’t even need to hit a cat scale unless I’m really close
    TheLoadOut and Tug Toy Thank this.
  7. xsetra
    xsetra Road Train Member
    4,921
    6,573
    Aug 21, 2011
    I would use a CAT scale with the first load to give you a good idea of what the reading will be.
    Then go to a DOT scale after that to fine tune the readings.
    Most Oregon scales are turned on even when the shack is closed.
    alds and TheLoadOut Thank this.
  8. TheLoadOut
    TheLoadOut Road Train Member
    1,826
    8,230
    Nov 6, 2019
  9. SmallPackage
    4,516
    13,598
    Dec 20, 2019
    Marion Texas
    That’s surprisizing they’d allow you to use a scale unattended. You’d think they’d be worried about sabatage or it getting out of calibration. Texas barricades them up. For once it sounds like the dot actually trusts drivers to do the right thing. Lol!
    D.Tibbitt Thanks this.
  10. SteveScott
    4,897
    16,803
    Nov 10, 2015
    Yeah Oregon is nice like that. Many states don't even show you your own weight when they're open. I hate that.
    D.Tibbitt, 86scotty and SmallPackage Thank this.
  11. 86scotty
    86scotty Road Train Member
    3,922
    10,217
    Aug 27, 2017
    Appalachia
    I've experienced this and it makes absolutely no sense to me.
    D.Tibbitt and SteveScott Thank this.
