Searching for opinions on a truck
Discussion in 'Ask An Owner Operator' started by AMW, Jan 21, 2022.
  1. AMW
    AMW Bobtail Member
    I'm interested in pulling a side-dump in state but would like the option to do some reefer/dry runs out of state and back when aggregate hauling gets slow. My questions, is there a combination spec'd truck that could work for both instances? Is this even a good idea? I realize that if it is spec'd more for hauling 85,000lbs the mpg won't be as good as an otr spec'd truck. Would it be better to just have 2 different trucks? Could I have a truck sitting not moving without insurance? If so could the insurance be transferred from truck to truck?
  3. Pup97
    Pup97 Light Load Member
    169
    187
    May 30, 2016
    I hauled 120k gross on a 40k airliner 3:42 rears for years. Spec how you want and replace parts when they wear out. Good thing about trucks, there made to be rebuilt.
    AMW Thanks this.
  4. AModelCat
    120,156
    If you looked for something a little beefier than a typical highway tractor with an aero hood/sleeper but no side skirts or low bumper. Could probably strike a decent balance. Low gearing in the rear end helps for soft ground so you'd probably be best with a 13 or 18 speed.
  5. ProfessionalNoticer
    2,048
    4,827
    Apr 25, 2021
    You'll need to keep both trucks insured/tagged. If you decide to run two of them keep that extra expense in mind as well.
    AMW Thanks this.
  6. Rubber duck kw
    5,686
    15,904
    Dec 9, 2017
    What AModelCat said. Get yourself something like a T800 Kenworth or one of the more aerodynamic Petes with no sideskirts or plastic bumpers. Something like a Freighliner is going to develop a lot of rattles and vibrations in the abuse of off road or semi off road you'll see pulling a side dump.
    AMW Thanks this.
  7. AMW
    AMW Bobtail Member
    Thanks guys. This info will help. I was thinking of a Pete 386, 379 or the KW T800 but I wasn't sure about the gearing in the rears. But anyway thanks again.
  • Draft saved Draft deleted
