i can't get any luck stopping oil leaks from valve cover gasket cleaned surfaces installed new gasket and oil is still weeping from under the gasket
SERIES 60 VALVE COVER LEAK
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckerbangin, Feb 17, 2016.
Is this a center bolt or parameter bolt style (what year)? Are you putting a dab of sealer on the corners of the front and rear cam caps? Are you sure it's from the gasket? Oil can leak from the cam caps, diamond seal, rear cam cover and wick down the valve cover gasket.
Did you replace the rubbers on the bolts? When they wear out, you loose the clamping force holding the valve cover down. This is very common with the older center bolt stay with the thick rubbers.Vampire Thanks this. -
You also should have the mesh filter for the breather vent. Doesn't hurt to pull that out and clean it good with carb or brake cleaner and blow it out to dry it. As that starts to plug, you get a little more crank case pressure that can make gaskets seep.areelius and truckerbangin Thank this. -
But a new style valve cover with bolts and the new style gasket, the head will accept it and it will seal much better. Also always put silicone in the corners of the cam caps and that should do it. It's not leaking out of the front diamond seal or perimeter seal and running down the valve cover is it?
truckerbangin and mnmover Thank this. -
Also check for hair line cracks in the cover.
truckerbangin Thanks this. -
I have same issue with 05 isx. Can the pressure cause this?
