Severe roughness and vibration after 3-4 minutes idling
Discussion in 'Experienced Truckers' Advice' started by JC1971, Dec 27, 2017.
  1. JC1971
    JC1971 Road Train Member
    2,368
    8,073
    Jul 29, 2013
    L.A.
    This is a 2017 Cascadia. It all started after I was towed. I'm thinking maybe the computer got fried when road service tried to jumpstart it. It only happens when idling after 3-4 minutes, and not every time. The dash menu starts saying crazy things like "wheel spin detected" when I'm not even moving or in gear. Any ideas?
  3. STexan
    STexan Road Train Member
    14,962
    29,144
    Oct 3, 2011
    Longview, TX
    I don't know, but I'm inclined to agree with your fear that you may have gotten some critical electronics fried. Or maybe you have a voltage problem related to a bad battery, poor post connection(s), or problem charging system.
    JC1971 Thanks this.
  4. street beater
    street beater Road Train Member
    4,578
    20,668
    Apr 18, 2014
    cold as hell, MN
    Set your idle high, if it doesn't happen with it cranked up its a voltage issue. Probably 1 or more shot batteries.
    JC1971 Thanks this.
  5. wore out
    wore out Numbered Classic
    14,322
    173,740
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Could be loose cables as well.
    SAR, Oxbow and JC1971 Thank this.
  6. JC1971
    2,368
    8,073
    Jul 29, 2013
    L.A.
    I just remembered. I got a truck wash the previous day. I didn't get the engine wash but they might have left the hood open to spray off the top.
  7. street beater
    4,578
    20,668
    Apr 18, 2014
    cold as hell, MN
    Dont see how thay could affect it
  8. Ridgeline
    20,660
    100,392
    This is like trying to guess what color the truck is.
    Get it to a dealer and have them hook it up to look at the error codes.
  9. skellr
    skellr Road Train Member
    8,737
    12,179
    Jul 17, 2011
    The Village, Portmeirion
    Disconnect the battery and let it sit for 15min.
    Lepton1 Thanks this.
  10. Lepton1
    Lepton1 Road Train Member
    12,647
    25,584
    Nov 23, 2012
    Yukon, OK
    In other words, reboot the truck. Might also be accomplished if the truck has a master switch.
  11. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,538
    May 22, 2017
    This all seems ironic if an electrical part has failed before a mechanical part. But I thought most mechanical parts are obsolete. Honestly if trucks are less reliable now what good are they. I guess I'll shut up now. Or I will keep rambling.
    Farmerbob1 and Lepton1 Thank this.
