Shifter gasket perforated
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Oct 20, 2019.
  1. Dino soar
    Dino soar Road Train Member
    2,225
    3,538
    Dec 8, 2017
    I'm looking at this gasket that goes on for my gear shift.
    I see perforations on this. Do these gaskets cover a bunch of different transmissions and you have to break out the area thats perforated for your application?
    As I set the gasket down on top of the transmission it does not look like I would need the center part.
  2. buddyd157
    buddyd157 Road Train Member
    9,115
    19,223
    May 25, 2017
    New England area
    my best guess, is yes. a multi-use gasket.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    2,719
    3,367
    Aug 26, 2014
    Just put the top on like it is.
  4. Working2party
    Working2party Medium Load Member
    608
    700
    Feb 10, 2018
    Kansas
    They do fit a broad range of applications. But there’s a lot of trial & error & try again with that gasket. What your seeing as punch outs and different bolt holes are drains. They figured out were they need to be so the tower doesn’t hold oil.
    Just make sure you line up the holes in it for the springs.
    mhyn and Dino soar Thank this.
  5. Dino soar
    2,225
    3,538
    Dec 8, 2017
    So I need to leave the gasket as is?
  6. starmac
    starmac Road Train Member
    6,677
    12,472
    Apr 11, 2019
    Fairbanks Ak
    Those three holes should line up with the detent balls iirc, I would just use as is
    .Match it up on the shift tower and make sure there is room in the center hole for it.
    Dino soar Thanks this.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,386
    Dec 29, 2008
    Northridge, CA
    you have latest gasket. it's for many Eaton fuller transmissions. Changed it on my 10 speed in September. $9 at freightliner dealers :)
  • Draft saved Draft deleted
