I have an annoying rattles that comes from the top of my shifter. Sounds like something is lose inside the top, right underneath the diagram of gear pattern. Not sure how to even get the top off to investigate. Any advice?
Shifter Rattles
Discussion in 'Experienced Truckers' Advice' started by RonnyM, Jun 19, 2016.
Page 1 of 3
Mine does the same thing (Eaton 10 speed). I've checked the screws, but that's about it. I've just learned to live with it.
Dumdriver Thanks this. -
The shift pattern is a little cap that is press fit on, there is usually a small nitch you can get the tip of a small screw driver or knife to pop off,
gentleroger, BUMBACLADWAR and Getsinyourblood Thank this.
My little shifting diagram used to pop completely off in a KW T680. Had to pop it back in a few times a week. Finally I fixed it with Gorilla Tape. Problem SOLVED.
Getsinyourblood Thanks this. -
kylefitzy Thanks this.
KriegHund, street beater and Lepton1 Thank this.
If you have a vibration, you want to check universal joints & make sure your driveline is not out of phase. -
I have had the same issue with an Eaton 10 speed..
It was not in the shifter but inside the trans....easy fix.....It took the shop about 45 minutes to pull the rubber boot off and the bolts on the top of the trans...replace nylon or some kind of bushing and it was like new again.
The sound just radiates up to the shift knob and tightening it does not work.
If you drive and rest your hand on the shift knob it wears that out. -
Page 1 of 3
