Sleep Apnea Questions
Discussion in 'Questions From New Drivers' started by KingpinR, Jun 20, 2014.
  1. KingpinR
    KingpinR Light Load Member
    56
    16
    Jun 28, 2013
    My wife would like to join me over the summer as I jump around the west coast. She has sleep apnea and is on a BPAP machine. I will either be in a new Pro Star or Cascadia by the middle of July.
    What sort of device would you recommend to power the machine. The company will not allow inverters.
    Thanks
  3. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    What they don't know won't hurt them. If you can use a cig lighter inverter to run the machine use it. When you go in for service or repairs hide it.
  4. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    tha tis od, that they wont allow them,i can see not allowing direct wire inverters but a plug in 400W shoud be no big deal
  5. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    http://www.dieselboss.com/cstore.htm
    If you go to this link you will find a plug in inverter as pictured below. If you are not a fan of Dieselboss'es you will be after doing business with them. They are to truckers what Gandhi was to India. I tip my hat (which they gave me) to them.
    [TABLE="class: center1100, width: 800"]
    [TR]
    [TD="width: 33%"]
    [​IMG][​IMG] [​IMG]
    DC to AC car and truck inverters
    Perfect for Laptop Power in the vehicle!
    [/TD]
    [TD][​IMG] Very small car or truck power inverter
    [​IMG] Plugs into the lighter socket
    [​IMG] For radios, laptops, cameras, games, more
    [​IMG] 150 watt and 400 watt versions
    Provides a steady current to run computers, stereos, video games, TVs, VCRs, emergency equipment and much more
    [/TD]
    [/TR]
    [/TABLE]
  6. Ridgeline
    22,368
    116,040
    Most of these units operate off of 12 volts for the cpap machine itself, the humidifier is a different story, but a lot of times you don't need to run it just have water in it.
  7. KingpinR
    56
    16
    Jun 28, 2013
    The humidifier is attached to the machine.
  8. Ridgeline
    22,368
    116,040
    Then call the supplier where you got it and ask them if the unit has a 12 volt power cord.
    There are a number of units on the used market that will work too, I've bought a few in the past for backups (another suggest is to have a backup) which were under $100 and DOT compliant.
