Sleeper Berth - No legroom problem - Advice Please
Discussion in 'Experienced Truckers' Advice' started by pypfm, Sep 27, 2026.
  1. pypfm
    pypfm Bobtail Member
    17
    18
    Dec 27, 2019
    Sleeper berth - pic 2.jpg Sleeper berth HVAC.jpg I drive OTR in a Volvo VNL 860 with a Thermo King APU. My problem is: I am a tall guy who sleeps on his stomach and due to the way the HVAC ductwork in the Volvo sleeper berth is set up (see attached pics), I've got no room to stretch my legs out fully. And because of that, I can't get comfortable at night, I can't sleep well, and I feel tired all the time = no good for doing this job!
    So, I'm looking into working for other trucking companies that have trucks with APU's/HVAC sleeper setups that do NOT take up the driver's legroom like my current crappy setup does. And my question to you guys is: Do Peterbilt 579's, Kenworth T680's, International LT's or Freightliner Cascadias with APU's have HVAC sleeper ductwork set up so that driver legroom isn't taken away?
    austinmike Thanks this.
  3. Arctic_fox
    4,808
    27,519
    Sep 16, 2016
    Most dont have that issue. My 579 tied into the sleeper vents. My lonestar has the AC on the wall. As for the legroom, it looks like the vent is at the top of that....thing. so id stuff a second matress or a matress spacer in under your bed. Velcro a soft mat of some kind in place and you should be good short term.
  4. Banker
    Banker Road Train Member
    4,958
    18,851
    Aug 19, 2012
    As a temporary solution go to Walmart and get you an air mattress and some egg carton looking foam. When I ran team we had a bed that was several feet taller than the standard mattress to insulate from the highway bumps. You can put it on top of or under your regular mattress and it will allow your feet to hang over the box that is in your way.
    I didn’t notice the comment above when I made my post. My suggestion is the same concept as his.
  5. Long FLD
    Long FLD Road Train Member
    13,470
    57,259
    Mar 4, 2015
    @cdavis188 is a tall guy who can fill you in on what it’s like in some other brands of trucks. I think he’s in a Volvo currently.
    pypfm Thanks this.
  6. tscottme
    tscottme Road Train Member
    1) raise your mattress so you have full window-to-window length.
    2) sleep on your side.
    Bean Jr. Thanks this.
  7. FearTheCorn
    FearTheCorn Heavy Load Member
    787
    3,277
    Jan 6, 2019
    Omaha
    If you raise the end of your mattress you can check out your windows. I don't know what truck your have, but if you have a side window, you can check out trucker chicks. It's a horror, but dude, try it out.
  8. Moosetek13
    Moosetek13 Road Train Member
    15,220
    19,519
    Nov 1, 2010
    Burnsville, MN
    You didn't even read the first sentence?
    "I drive OTR in a Volvo VNL 860 with a Thermo King APU."
  9. 86scotty
    86scotty Road Train Member
    4,931
    13,680
    Aug 27, 2017
    Appalachia
    Taller mattress solves this problem. A friend of mine did this for the same reason.
    pypfm Thanks this.
  10. cdavis188
    cdavis188 Road Train Member
    4,669
    17,479
    Jun 10, 2021
    Salina, KS
    I'm 6'8 and currently drive an 860 Volvo. My feet usually end up in that cubby. Which isn't a big deal except I knock out the HVAC tube on a routine basis. Cascadia's I've driven don't have that problem, however the mattress is loose and there's space between the mattress and either side of the sleeper where pillows and other stuff can end up at. I don't particularly like that. Both trucks have their pros and cons to how my particular company have the sleepers set up.
    It's been awhile since I've had my 579 but I recall I didn't have any major issues with the sleeper and generally preferred it to the Freightliner except for the tiny fridge. I believe T680's are set up similarly.
    If you can, I would test out the sleepers of other trucks and see how you like the mattress setup
    Magoo1968 and pypfm Thank this.
  11. Accidental Trucker
    Accidental Trucker Road Train Member
    3,474
    7,947
    Jun 4, 2015
    I’m 6’5” and have no issues at all in a T680. However, for $500 you can get a 12” or thicker top of the line mattress, or get an underlay/ overlay for even less.
    No sleep is not an option. And a couple of hundred bucks is much cheaper than changing companies.
    tscottme, Speedy356 and pypfm Thank this.
