Slow crank no start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by FREDthaCEO, Jul 8, 2026.
  1. FREDthaCEO
    FREDthaCEO Bobtail Member
    17
    Mar 6, 2021
    I have a 2007 freightliner Columbia it was sitting a few months but I decided to put it back on the road.. I had 4 batteries in the truck but when I went to crank it gave me nothing (I already figured it wouldn’t start) but when I put 4 brand new batteries in it… it’s turning slow but won’t crank.. is it possible for me to troubleshoot or do I just need to go ahead and get a new starter.. my starter was not dragging before I let the truck sit
  3. W923
    W923 Road Train Member
    1,451
    4,523
    Feb 28, 2022
    Check the voltage of the big cable at the starter while someone else cranks it if it’s below 10 check at the battery while it’s cranking and see what it is there then start checking connections
    Magoo1968 Thanks this.
  4. Raffito
    Raffito Light Load Member
    88
    55
    Aug 25, 2019
    Ingram, TX
    If all your battery cables are tight you can check the cable at the starter, by try crank it over then check the cable at the starter to see if they get hot. If the ground or the positive get hot means you have loose or dirty connection. if your stater is getting hot, that means it's time to change it. Before you do that make sure you don't have a bad a/c compressor.
