Vapor Coming in front of the radiator. Coolant level steel good. Should I put stop leak treatment and which one? Or should go to the shop?
Thanks
Small Radiator Leak
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by amarillasleo, Apr 22, 2018.
No to stop leak, just messes up everything else.
Expeditor, kemosabi49 and AModelCat Thank this. -
I would never put anything in rad. Find the leak and have it repaired.
AModelCat Thanks this. -
Got it. Thank you
Make sure it’s not a damaged/cut silicone hose. I had one where the cut was underneath the clamp on the bottom side of the hose. Chased that leak for a while. It really looked like it was coming from the Rad itself. Maybe a pressure test would help make sure.
Good luck -
Good Idea. Thank You
