Spread axle dry van
Discussion in 'Questions From New Drivers' started by springbrake, Apr 9, 2010.
  1. springbrake
    springbrake Light Load Member
    211
    69
    Mar 13, 2010
    What do these haul and why the spread axle like the flatbeds? Are they allowed 40,000lbs on the rear axles?
  3. jtrnr1951
    jtrnr1951 Road Train Member
  4. springbrake
    211
    69
    Mar 13, 2010
    I saw the diesel tank underneath and figured reefer of some sort.
    Why the spread axle though? Delivering to a halfway point or some dropoff point?
    I am new but I imagine backing one of those into a dock at any significant angle isn't all too smooth.
  5. musicmaker
    musicmaker Medium Load Member
    561
    145
    Dec 25, 2009
    Fort Madison, IA
    thats what they make the lift kits for. Lift that front axle when backing. The reason for the spreads are for the weight, 40,000 on the spread. For reefers that helps when hauling produce that has been packed in ice
    Saddle Tramp and The Challenger Thank this.
  6. semijoesd
    semijoesd Bobtail Member
    39
    13
    Aug 30, 2008
    san diego, ca
    10-4 mr/ music maker is on the money! God bless
    The Challenger Thanks this.
  7. rbht
    rbht Heavy Load Member
    888
    525
    Jan 23, 2010
    CT,NH
    There allowed 40,000lbs on the rear and the ride is much better than a closed tandem and if you have a dump on your back axel a spread will turn tighter then a closed tandem will and never have to worry about sliding your axel's for wheight transfer just load more toward the back and 99% of the time your good to go plus in some state's i now VT for 1 they will allow you 3% over if you have a spread.
    Saddle Tramp and heyns57 Thank this.
  8. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    Yeah you can load spreads heavy to the rear 40k, but come to states like LA, and
    TX and you can't have more than 20k per axle.
    And believe me they WILL split your axles on the scale to make sure your not over.
    Saddle Tramp Thanks this.
  9. heyns57
    heyns57 Road Train Member
    2,209
    1,011
    Dec 30, 2006
    near Kalamazoo Speedway
    I hauled beer on an older air-ride spread axle. It was 12'6" tall, with a roll up door. I used that trailer on multi-stop pickups when load planning was difficult, or when no truck stop scale was available before the state scales.
