Spread axle tires
Discussion in 'Flatbed Trucking Forum' started by Boardhauler, Jul 9, 2026.
  1. Boardhauler
    Boardhauler Road Train Member
    1,775
    4,133
    Dec 21, 2008
    Ballin' in it for Shakey
    When I bought this trailer it came with a pretty motley collection of recap tires. A month or so ago I went to the local Southern Tire Mart with the idea of upgrading to new virgin rubber, a pair at a time.
    What the boss there told me is that they basically don't stock any new trailer tires because nobody in the county runs them and he wasn't sure what to recommend for a spread axle if I wanted to order some.
    We decided to throw a couple of recaps on as a temporary solution while we both did a little research on the matter. He assured me that the tires he sold me are the local favorites and handle the scrub from a spread axle well. I told him I wasn't as worried about scrub as I was about running high speeds in hot weather for long distances.
    This is what one of them did today under those very conditions.
    That was a big pop, and not just the noise it made.
    So - do any of y'all have have any preferences for tires on a spread? When I pulled curtain van we ran Michelin wide singles & they actually did well, but I'm not huge fan of Michelin or wide singles. I'm not backing into docks every day like I did with a curtain, but I'm not in the mood to slow down because it's hot.
    OLDSKOOLERnWV, Feedman, cke and 3 others Thank this.
  3. FLHT
    FLHT Road Train Member
    1,486
    2,747
    Aug 2, 2014
    Southern Tire carries several virgin tire brands down here in the South.
    Don,t see many caps around here its just to dam hot.
    Best tires for wear I had some Hankooks.
    The big LTL fleets run caps on everything but steers.
  4. Razororange
    Razororange Road Train Member
    2,812
    26,746
    Dec 20, 2011
    Milwaukee, WI
    Got Roadmaster RM272 on most of my trailers at this point. No issues at all with the 255/70/22.5 tires. Have run many sets until they were near minimum legal tread. Probably get 2-3 years out of them. Almost always end up doing all 8 at the same time.
    The smaller 245/70/17.5s I do blow up on occasion but that's because I run them on my 60T trailer and they only go when loaded up to the ratings and I accidentally get moving a bit too fast during the summer. I also do some terrible things to the little tires with having to drop my booster and jack the trailer into tight places with 100K on 3 axles.
    Used to run all Michelin or Continentals on the big trailer but they weren't lasting any longer and were twice the price.
    Stopped running recaps like 8-10 years ago. Whatever was saved by getting cheaper tires was lost when they would blow up and wipe out fenders on a truck or the cross members under the trailer. Not to mention the cost of the road service to replace the blown tires.
  5. CAXPT
    CAXPT Road Train Member
    3,498
    16,675
    Feb 10, 2008
    Yokohama and Continental come to mind from the one's I've had on my trailers.
    OldeSkool Thanks this.
  6. xsetra
    xsetra Road Train Member
    5,204
    7,161
    Aug 21, 2011
    I run New Firestone on my spread axle stepdeck 22.5's. Previous trailers that used 17.5's and 19.5's I couldn't find any good tires to last a full summer running in the heat, without running slower than speed limits.
    CAXPT Thanks this.
  7. 2CAN
    2CAN Medium Load Member
    623
    2,809
    Jan 7, 2010
    Toyo M154 or Michelin XZE I've had both go almost 200k on a spread, zero issues.
    I bought a new to me trailer with a big spread that came with Firestone 561? that seem ok
    if you go with Toyo most places will tell you they are a steer tire but it is an all position tire
    Oldman83, CAXPT and OldeSkool Thank this.
  8. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,057
    2,279
    Dec 15, 2021
    201 Road Train Member
    12,971
    26,741
    Apr 16, 2014
    high plains colorado
    Years ago, I knew O/Os that had spread axles, and they had one of the rear axles on a lift, usually the rear one. Not only less tolls, but didn't experience that scuff on turns.
    CAXPT Thanks this.
  10. cke
    cke Road Train Member
    6,360
    78,374
    Aug 4, 2013
    Colfax Wi
    ANYTHING but a recap.
  11. Sons Hero
    Sons Hero Road Train Member
    3,659
    39,054
    Jan 8, 2021
    Indiana
    Anything but a recap, or a Doublecoin.
    Oldman83 and CAXPT Thank this.
