Squealing
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Samot, May 22, 2019.
  1. Samot
    Samot Bobtail Member
    44
    7
    Mar 5, 2009
    Georgia
    I have a 2004 Pete dump truck with a C13. I can’t figure out where this squealing is coming from. I’ve put on a new AC compressor, belt, tensioner and a fan hub. I brought it somewhere and they vacuumed the freon out and supposedly flushed the system. They changed the orfice tube and when I picked it up it didn’t make a sound at all for the first 24 hours but it’s back. Any suggestions ?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Check both of idler pulley? What brand of belt?
    Oxbow Thanks this.
  4. Samot
    44
    7
    Mar 5, 2009
    Georgia
    Yes to both pulleys. Not sure on the brand of belt but this is the second belt I’ve tried just for haha. It seems to do when the AC kicks in ?
  5. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    Maybe it's the a/c compressor then
  6. spsauerland
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    You have a picture of how you have the belt routed? Used to have trouble with the same setup and the cure was Goodyear/Continental gator back belts.
    Oxbow Thanks this.
  7. Deere hunter
    1,936
    8,408
    Aug 5, 2017
    Shallowater Texas
    Compressor may be trying to lock up after it builds pressure !
    x1Heavy Thanks this.
  8. Mr Bob
    Mr Bob Light Load Member
    262
    81
    Mar 17, 2015
    Yup sounds like you need to pressure test the A / C system
  9. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    Yes please pressure test it. Check and see if your belts are enduring being slipped across something that is not rolling with the belt. Any kind of noise from there like squealing is telling you shes hurting somewhere. Either at the compressor or one of the rollers around the path for the engine belt.
